주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BlackBerry PlayBook USB Port Replacement
필요한 것
    1. BlackBerry PlayBook USB Port Replacement, Remove Back Panel: 1 단계, 이미지 2개 중 1개 BlackBerry PlayBook USB Port Replacement, Remove Back Panel: 1 단계, 이미지 2개 중 2개
      • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
      • There are clips that need to be released on all four sides of the device.
      • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
      댓글 쓰기
    1. BlackBerry PlayBook USB Port Replacement, Motherboard: 2 단계, 이미지 2개 중 1개 BlackBerry PlayBook USB Port Replacement, Motherboard: 2 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Remove the battery connector using either your fingers or a pair of tweezers.
      댓글 쓰기
    2. BlackBerry PlayBook USB Port Replacement: 3 단계, 이미지 2개 중 1개 BlackBerry PlayBook USB Port Replacement: 3 단계, 이미지 2개 중 2개
      • Unscrew two 1.17x2.9mm Phillips screws from the white connector port.
      • Lift the battery connector away from the motherboard using a spudger.
      댓글 쓰기
    3. BlackBerry PlayBook USB Port Replacement: 4 단계, 이미지 2개 중 1개 BlackBerry PlayBook USB Port Replacement: 4 단계, 이미지 2개 중 2개
      댓글 쓰기
    4. BlackBerry PlayBook USB Port Replacement: 5 단계, 이미지 2개 중 1개 BlackBerry PlayBook USB Port Replacement: 5 단계, 이미지 2개 중 2개
      댓글 쓰기
    5. BlackBerry PlayBook USB Port Replacement: 6 단계, 이미지 3개 중 1개 BlackBerry PlayBook USB Port Replacement: 6 단계, 이미지 3개 중 2개 BlackBerry PlayBook USB Port Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the clipped ZIF data connector coming from underneath the motherboard.
      • Lift up the black plastic clip with a spudger.
      • Pull the connector out gently using tweezers.
      • Be careful to ensure that the black plastic clip has been lifted away from the connector ribbon before pulling on the connector. The clip should be loose and easy to wiggle. Removing the connector before it is unclipped can cause damage.
      댓글 쓰기
    6. BlackBerry PlayBook USB Port Replacement, Unscrew Motherboard: 7 단계, 이미지 1개 중 1개
      • Remove the following five screws from the motherboard.
      • Three 1.5x2.5mm Phillips screws
      • Two 1.55x2.38mm Phillips screws
      댓글 쓰기
    7. BlackBerry PlayBook USB Port Replacement, Remove Wire Leads: 8 단계, 이미지 1개 중 1개
      댓글 쓰기
    8. BlackBerry PlayBook USB Port Replacement, Remove Motherboard: 9 단계, 이미지 2개 중 1개 BlackBerry PlayBook USB Port Replacement, Remove Motherboard: 9 단계, 이미지 2개 중 2개
      • Gently lift the motherboard away from the device. If there is any resistance, check the previous steps to ensure that all connections have been removed.
      댓글 쓰기
    1. BlackBerry PlayBook USB Port Replacement, Desolder the USB port: 10 단계, 이미지 1개 중 1개
      • Use your soldering skills to detach the USB port from the motherboard at the following two solder joints.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 15명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Nathan
회원 가입일: 10/12/14
682 평판
안내서 4개를 작성함
Cal Poly, Team 14-27, Maness Fall 2014 Cal Poly, Team 14-27, Maness Fall 2014 회원
CPSU-MANESS-F14S14G27
4 회원들
안내서 12개를 작성함
6가이드 댓글
excelent step by step guide not taking peoples knowledge for granted good stuff rgards pete smith.
callum Smith - 답글 공유
Fantastically easy to follow step by step instructions with diagrams that are superbly explained - afterall I am but a 'mere woman's!! Thankyou, I love this site. Definitely *****
Justine Franklin - 답글 공유
J'ai changer les batteries et j'ai une image plein de ligne,qu'est-ce qu'il se passe ?
Sylvain - 답글 공유
I was defeated but the USB port which has proof impossible to unsolder. I give up.. let’s just hold I have not damaged the board
Stephen Missah - 답글 공유
i had tge same issue, cant desolder? what to do now, its in my hand right now.
catmando1962 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 54
전체 시간: 13,560
