주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BlackBerry World Edition 8830 Microphone Replacement
필요한 것
  1. BlackBerry World Edition 8830 Microphone Replacement, Battery: 1 단계, 이미지 3개 중 1개 BlackBerry World Edition 8830 Microphone Replacement, Battery: 1 단계, 이미지 3개 중 2개 BlackBerry World Edition 8830 Microphone Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before beginning this installation, make sure phone is powered off .
    • Turn phone over to the backside.
    • Press down on the lower portion of the back cover.
    • Slide the lower portion down to remove the cover and reveal the battery.
    댓글 쓰기
  2. BlackBerry World Edition 8830 Microphone Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery from the phone.
    댓글 쓰기
  3. BlackBerry World Edition 8830 Microphone Replacement, Front and Back Casing: 3 단계, 이미지 2개 중 1개 BlackBerry World Edition 8830 Microphone Replacement, Front and Back Casing: 3 단계, 이미지 2개 중 2개
    • Once the battery is removed, remove the four 9.2 mm screws with the T4 Torx Screwdriver.
    댓글 쓰기
  4. BlackBerry World Edition 8830 Microphone Replacement: 4 단계, 이미지 3개 중 1개 BlackBerry World Edition 8830 Microphone Replacement: 4 단계, 이미지 3개 중 2개 BlackBerry World Edition 8830 Microphone Replacement: 4 단계, 이미지 3개 중 3개
    • Remove side panels with the Plastic Opening Tool by sliding it along the edge of the panel until you can pry it off with the tool.
    댓글 쓰기
  5. BlackBerry World Edition 8830 Microphone Replacement: 5 단계, 이미지 2개 중 1개 BlackBerry World Edition 8830 Microphone Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the back casing using the Plastic Opening Tool
    • Once the back casing is removed the top two buttons are likely to pop out.
    댓글 쓰기
  6. BlackBerry World Edition 8830 Microphone Replacement: 6 단계, 이미지 3개 중 1개 BlackBerry World Edition 8830 Microphone Replacement: 6 단계, 이미지 3개 중 2개 BlackBerry World Edition 8830 Microphone Replacement: 6 단계, 이미지 3개 중 3개
    • Locate the two 9.2mm screws on the upper inside casing
    • Remove them using the T4 Torx Screwdriver
    • Slide off the front casing once the screws are removed.
    • Trackball will fall out once the casing is removed.
    댓글 쓰기
  7. BlackBerry World Edition 8830 Microphone Replacement, Microphone: 7 단계, 이미지 2개 중 1개 BlackBerry World Edition 8830 Microphone Replacement, Microphone: 7 단계, 이미지 2개 중 2개
    • Once the microphone is revealed, use the flathead screwdriver, or the tip of a knife, to carefully pry the microphone out of the hole.
    • Be careful not to bend the ring around the microphone when prying it out. If the ring does get bent you may not be able to replace the microphone.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
tbace
회원 가입일: 04/18/12
28 평판
안내서 2개를 작성함
Cal Poly, Team 17-27, Amido Spring 2012 Cal Poly, Team 17-27, Amido Spring 2012 회원
CPSU-AMIDO-S12S17G27
4 회원들
안내서 23개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 26
전체 시간: 1,107
