주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Blackberry Bold 9650 Keypad Replacement
필요한 것
  1. Blackberry Bold 9650 Keypad Replacement, Battery: 1 단계, 이미지 2개 중 1개 Blackberry Bold 9650 Keypad Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
    댓글 쓰기
  2. Blackberry Bold 9650 Keypad Replacement: 2 단계, 이미지 1개 중 1개
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
    댓글 쓰기
  3. Blackberry Bold 9650 Keypad Replacement, SIM Card: 3 단계, 이미지 1개 중 1개
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
    댓글 쓰기
  4. Blackberry Bold 9650 Keypad Replacement: 4 단계, 이미지 1개 중 1개
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
    댓글 쓰기
  5. Blackberry Bold 9650 Keypad Replacement, Back Chassis: 5 단계, 이미지 1개 중 1개
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
    댓글 쓰기
  6. Blackberry Bold 9650 Keypad Replacement: 6 단계, 이미지 1개 중 1개
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
    댓글 쓰기
  7. Blackberry Bold 9650 Keypad Replacement: 7 단계, 이미지 1개 중 1개
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
    댓글 쓰기
  8. Blackberry Bold 9650 Keypad Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
    댓글 쓰기
  9. Blackberry Bold 9650 Keypad Replacement, Mother Board: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
    • Using a pair of tweezers, lift and remove the following:
    • The two round connectors on the top of the mother board.
    • The round connectors are hooked into the mother board.
    • The flat connector in the lower corner of the mother board.
    댓글 쓰기
  10. Blackberry Bold 9650 Keypad Replacement: 10 단계, 이미지 1개 중 1개
    • Using your fingers, carefully lift and remove the mother board.
    • The connectors underneath the mother board are delicate and easily damaged.
    댓글 쓰기
  11. Blackberry Bold 9650 Keypad Replacement: 11 단계, 이미지 1개 중 1개
    • Using a pair of tweezers, remove the three ribbon connectors.
    댓글 쓰기
  12. Blackberry Bold 9650 Keypad Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the mother board by lifting the board upward.
    댓글 쓰기
  13. Blackberry Bold 9650 Keypad Replacement, Faceplate: 13 단계, 이미지 2개 중 1개 Blackberry Bold 9650 Keypad Replacement, Faceplate: 13 단계, 이미지 2개 중 2개
    • Using a pry tool, lift up on the four tabs located on the edges of the faceplate.
    • Remove the faceplate by lifting the plate upward.
    댓글 쓰기
  14. Blackberry Bold 9650 Keypad Replacement, Keypad: 14 단계, 이미지 1개 중 1개
    • Lift the keypad out of the the front cover.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ryan
회원 가입일: 03/12/12
696 평판
안내서 11개를 작성함
Clemson, Team 2-5, Benson Spring 2012 Clemson, Team 2-5, Benson Spring 2012 회원
CLEM-BENSON-S12S2G5
2 회원들
안내서 25개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 32
전체 시간: 7,691
