주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Blackberry Classic Battery Replacement
필요한 것
    1. Blackberry Classic Battery Replacement, Remove SIM and SD Tray: 1 단계, 이미지 3개 중 1개 Blackberry Classic Battery Replacement, Remove SIM and SD Tray: 1 단계, 이미지 3개 중 2개 Blackberry Classic Battery Replacement, Remove SIM and SD Tray: 1 단계, 이미지 3개 중 3개
      • Use a SIM tool to remove the SIM and micro SD card trays.
      댓글 쓰기
    2. Blackberry Classic Battery Replacement, Remove Battery Cover: 2 단계, 이미지 3개 중 1개 Blackberry Classic Battery Replacement, Remove Battery Cover: 2 단계, 이미지 3개 중 2개 Blackberry Classic Battery Replacement, Remove Battery Cover: 2 단계, 이미지 3개 중 3개
      • Use a Jimmy to pry between the midframe and back cover. Wiggle back and forward until the first clip releases.
      • Switch to a plastic spudger and continue gently prying along the edge of the back cover to release the clips.
      • Once all the clips are released around the edge of the cover, you will need to use a guitar pick to cut through adhesive on the top and bottom of the cover. Take care not to cut through the battery ribbon cable. The top adhesive is behind the glass feature on the back cover. You may need to apply some heat.
      댓글 쓰기
    3. Blackberry Classic Battery Replacement, Disconnect Battery: 3 단계, 이미지 3개 중 1개 Blackberry Classic Battery Replacement, Disconnect Battery: 3 단계, 이미지 3개 중 2개 Blackberry Classic Battery Replacement, Disconnect Battery: 3 단계, 이미지 3개 중 3개
      • One T5 (lower) and one PH00 (upper) screwdriver heads are needed to remove the battery's connector shield.
      • Then use a spudger to pry the battery's connector from the motherboard. Be sure to pry with even pressure.
      댓글 쓰기
    4. Blackberry Classic Battery Replacement, Remove Battery: 4 단계, 이미지 3개 중 1개 Blackberry Classic Battery Replacement, Remove Battery: 4 단계, 이미지 3개 중 2개 Blackberry Classic Battery Replacement, Remove Battery: 4 단계, 이미지 3개 중 3개
      • Use extreme caution when removing the battery. It is directly against the motherboard, and piercing the battery could corrode other components. It could also catch flame.
      • Take off the battery shield, and use a scalpel or other flat tool to remove the foam on the connector. Place these onto new battery.
      • Carefully apply some low heat to the stickers covering the battery and gently peel them off. The white sticker is connected to adhesive under the battery.
      • Gently pry up on the edges of the battery so that the adhesive will come out more easily. Take great care not to pierce the black "skin" on the battery.
      • Slowly start pulling the adhesive tab out, regripping close to the battery as it starts to come out.
      댓글 쓰기
    5. Blackberry Classic Battery Replacement, Remove Battery Cont'd: 5 단계, 이미지 3개 중 1개 Blackberry Classic Battery Replacement, Remove Battery Cont'd: 5 단계, 이미지 3개 중 2개 Blackberry Classic Battery Replacement, Remove Battery Cont'd: 5 단계, 이미지 3개 중 3개
      • Be sure to add adhesive to the new battery, and replace the foam on the connector.
      댓글 쓰기
    6. Blackberry Classic Battery Replacement: 6 단계, 이미지 1개 중 1개
      • Adhesive is best around outer edges.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Remember to replace the foam pad on the connector.
취소: 해당 안내서를 완성하지 않았습니다.
다른 18명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jessica Pickering
회원 가입일: 02/21/17
624 평판
안내서 1개를 작성함
Circuits Cell Shop Circuits Cell Shop 회원
Business
1 회원
안내서 8개를 작성함
8가이드 댓글
thank you so much
ttlchan - 답글 공유
Glad it helped!
Jessica Pickering - 답글 공유
Success! Nerve racking for an amateur and I could not have done it without your guidance.
Thank you.
Ken Wright - 답글 공유
So happy to be of help!
My BB is going to have a 2nd life. Unbelievably irresponsible to glue everything together.
Thx Jessica for this great guide. It worked perfectly and in a spell.
Erwin Silberstein - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 76
지난 30일: 206
전체 시간: 32,667
