주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Blackberry Torch 9810 Cursor Key Replacement
필요한 것
  1. Blackberry Torch 9810 Cursor Key Replacement, Phone cover: 1 단계, 이미지 2개 중 1개 Blackberry Torch 9810 Cursor Key Replacement, Phone cover: 1 단계, 이미지 2개 중 2개
    • Remove the back cover of the phone
    댓글 쓰기
  2. Blackberry Torch 9810 Cursor Key Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Remove the battery
    댓글 쓰기
  3. Blackberry Torch 9810 Cursor Key Replacement, Remove screws: 3 단계, 이미지 1개 중 1개
    • Unscrew the four screws using the T6 screw driver.
    • If you remove the screw in red, you void the warranty!
    댓글 쓰기
  4. Blackberry Torch 9810 Cursor Key Replacement, Wiggle Wiggle: 4 단계, 이미지 2개 중 1개 Blackberry Torch 9810 Cursor Key Replacement, Wiggle Wiggle: 4 단계, 이미지 2개 중 2개
    • Slide the screen up.
    • Remove front silver trim by using a plastic opening tools and wiggle it off.
    • This is difficult to remove, but it should come off if you do it with caution.
    댓글 쓰기
  5. Blackberry Torch 9810 Cursor Key Replacement, More screws that need to go: 5 단계, 이미지 1개 중 1개
    • Once you remove the rim cover, you should find two more screws on the top. Unscrew them with a T-6 screw driver.
    댓글 쓰기
  6. Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: 6 단계, 이미지 3개 중 1개 Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: 6 단계, 이미지 3개 중 2개 Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: 6 단계, 이미지 3개 중 3개
    • Use the plastic opening tools to remove the entire back off the phone.
    댓글 쓰기
  7. Blackberry Torch 9810 Cursor Key Replacement, Remove Ribbon Cables: 7 단계, 이미지 1개 중 1개
    • Remove the three ribbon cables and the antenna wire by hand.
    • The cable in red is glued to the metal cap. Peel it upwards towards the battery compartment.
    댓글 쓰기
  8. Blackberry Torch 9810 Cursor Key Replacement, Remove Logic Board: 8 단계, 이미지 1개 중 1개
    • The logic board will easily pull straight out.
    댓글 쓰기
  9. Blackberry Torch 9810 Cursor Key Replacement, Remove Informational Sticker: 9 단계, 이미지 1개 중 1개
    • Remove the black sticker located above the logic board that contains the phone's serial number
    댓글 쓰기
  10. Blackberry Torch 9810 Cursor Key Replacement, Remove More Screws: 10 단계, 이미지 1개 중 1개
    • Behind the black sticker you should find six small yellow screws. Remove them with a T4 torx screwdriver.
    댓글 쓰기
  11. Blackberry Torch 9810 Cursor Key Replacement, Separate the phone: 11 단계, 이미지 1개 중 1개
    • Carefully separate the screen from the body.
    • Make sure to be extra careful with the ribbon!
    댓글 쓰기
  12. Blackberry Torch 9810 Cursor Key Replacement: 12 단계, 이미지 1개 중 1개
    • Slide the silver plate up and you should find four more screws that need to be removed. Use a T-4 screw driver.
    • They are on a black cover located on the bottom of the phone. The black cover will come off
    댓글 쓰기
  13. Blackberry Torch 9810 Cursor Key Replacement, Carefully Remove a Ribbion: 13 단계, 이미지 1개 중 1개
    • There is one last orange ribbon cable that needs to be pulled and behind it is the cursor
    댓글 쓰기
  14. Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: 14 단계, 이미지 3개 중 1개 Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: 14 단계, 이미지 3개 중 2개 Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: 14 단계, 이미지 3개 중 3개
    • Push the cursor upwards and out of the socket.
    • Gently pull out the white box by pulling straight out of the socket to the right. This is your cursor
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jocelyn Adorno
회원 가입일: 10/16/14
314 평판
안내서 4개를 작성함
UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G6
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 14
전체 시간: 1,795
