주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Blu Studio HD 6.0 Microphone Replacement
필요한 것
  1. Blu Studio HD 6.0 Microphone Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
    • Begin by making sure your Blu Studio is turned off.
    댓글 쓰기
  2. Blu Studio HD 6.0 Microphone Replacement, Back Panel.: 2 단계, 이미지 2개 중 1개 Blu Studio HD 6.0 Microphone Replacement, Back Panel.: 2 단계, 이미지 2개 중 2개
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
    댓글 쓰기
  3. Blu Studio HD 6.0 Microphone Replacement: 3 단계, 이미지 2개 중 1개 Blu Studio HD 6.0 Microphone Replacement: 3 단계, 이미지 2개 중 2개
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
    댓글 쓰기
  4. Blu Studio HD 6.0 Microphone Replacement, Midframe: 4 단계, 이미지 2개 중 1개 Blu Studio HD 6.0 Microphone Replacement, Midframe: 4 단계, 이미지 2개 중 2개
    • With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00)
    댓글 쓰기
  5. Blu Studio HD 6.0 Microphone Replacement: 5 단계, 이미지 1개 중 1개
    • Next proceed to remove all 16 screws (2.5mm in length), all screws are the same size so getting them mixed up will not be an issue later on.
    • One of the lower right hand screws will be hidden under a sticker.
    댓글 쓰기
  6. Blu Studio HD 6.0 Microphone Replacement: 6 단계, 이미지 1개 중 1개
    • After removing all 16 screws you can begin the process of removing the battery housing panel.
    • You will need to use the thinner plastic prying tool to slowly outline the seem of the case starting from the top (near the camera).
    • Try to be careful around the side buttons as the plastic is weakest there.
    • After the top half of the case has been opened insert the thicker prying tool to keep the case open. This will help as the battery and battery housing have a suction cup like action that keeps them from separating.
    댓글 쓰기
  7. Blu Studio HD 6.0 Microphone Replacement: 7 단계, 이미지 1개 중 1개
    • At this point your battery, motherboard, rear camera, and front camera should all be readily available for fixing. Happy fixing.
    댓글 쓰기
  8. Blu Studio HD 6.0 Microphone Replacement, Locate the microphone.: 8 단계, 이미지 2개 중 1개 Blu Studio HD 6.0 Microphone Replacement, Locate the microphone.: 8 단계, 이미지 2개 중 2개
    • The microphone is located at the rear-lower-left corner.
    댓글 쓰기
  9. Blu Studio HD 6.0 Microphone Replacement, Separate the old microphone.: 9 단계, 이미지 2개 중 1개 Blu Studio HD 6.0 Microphone Replacement, Separate the old microphone.: 9 단계, 이미지 2개 중 2개
    • Lift the microphone very carefully.
    • Unsolder the two lower wires ( one red wire and one black wire ).
    댓글 쓰기
  10. Blu Studio HD 6.0 Microphone Replacement, Solder the new microphone.: 10 단계, 이미지 1개 중 1개
    • Solder the new microphone in the same spot. The black wire will go in the lower spot and the red wire in the upper spot.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ernesto Diaz
회원 가입일: 09/23/14
1,759 평판
안내서 3개를 작성함
USF Tampa, Team 9-1, Blackwell Fall 2014 USF Tampa, Team 9-1, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S9G1
3 회원들
안내서 8개를 작성함
2가이드 댓글
Where can I get a blue microphone for my BLU phone. When I answer my BLU phone I can't hear the person on the other line but they cannot hear me so I believe it's just my microphone when I speak.
Christina - 답글 공유
Where can I buy microphones
b langdon - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 46
전체 시간: 14,091
