주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Blu Studio HD 6.0 Volume Buttons replacement
필요한 것
  1. Blu Studio HD 6.0 Volume Buttons replacement, Rear Case: 1 단계, 이미지 1개 중 1개
    • Begin by making sure your Blu Studio is turned off.
    댓글 쓰기
  2. Blu Studio HD 6.0 Volume Buttons replacement, Back Panel.: 2 단계, 이미지 2개 중 1개 Blu Studio HD 6.0 Volume Buttons replacement, Back Panel.: 2 단계, 이미지 2개 중 2개
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
    댓글 쓰기
  3. Blu Studio HD 6.0 Volume Buttons replacement: 3 단계, 이미지 2개 중 1개 Blu Studio HD 6.0 Volume Buttons replacement: 3 단계, 이미지 2개 중 2개
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
    댓글 쓰기
  4. Blu Studio HD 6.0 Volume Buttons replacement, Midframe: 4 단계, 이미지 2개 중 1개 Blu Studio HD 6.0 Volume Buttons replacement, Midframe: 4 단계, 이미지 2개 중 2개
    • With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00)
    댓글 쓰기
  5. Blu Studio HD 6.0 Volume Buttons replacement: 5 단계, 이미지 1개 중 1개
    • Next proceed to remove all 16 screws (2.5mm in length), all screws are the same size so getting them mixed up will not be an issue later on.
    • One of the lower right hand screws will be hidden under a sticker.
    댓글 쓰기
  6. Blu Studio HD 6.0 Volume Buttons replacement: 6 단계, 이미지 1개 중 1개
    • After removing all 16 screws you can begin the process of removing the battery housing panel.
    • You will need to use the thinner plastic prying tool to slowly outline the seem of the case starting from the top (near the camera).
    • Try to be careful around the side buttons as the plastic is weakest there.
    • After the top half of the case has been opened insert the thicker prying tool to keep the case open. This will help as the battery and battery housing have a suction cup like action that keeps them from separating.
    댓글 쓰기
  7. Blu Studio HD 6.0 Volume Buttons replacement: 7 단계, 이미지 1개 중 1개
    • At this point your battery, motherboard, rear camera, and front camera should all be readily available for fixing. Happy fixing.
    댓글 쓰기
  8. Blu Studio HD 6.0 Volume Buttons replacement, Locate the volume buttons.: 8 단계, 이미지 1개 중 1개
    • The volume buttons are located on the rear-upper-right side of your Blu Studio phone.
    댓글 쓰기
  9. Blu Studio HD 6.0 Volume Buttons replacement, Replace the buttons.: 9 단계, 이미지 2개 중 1개 Blu Studio HD 6.0 Volume Buttons replacement, Replace the buttons.: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using the tweezers lift the volume buttons and unsolder the buttons connection.
    댓글 쓰기
  10. Blu Studio HD 6.0 Volume Buttons replacement, Solder the new buttons.: 10 단계, 이미지 2개 중 1개 Blu Studio HD 6.0 Volume Buttons replacement, Solder the new buttons.: 10 단계, 이미지 2개 중 2개
    • Finally you solder the new buttons to the motherboard of your Blu Studio.
    • Make sure that your buttons are placed as shown in the picture.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ernesto Diaz
회원 가입일: 09/23/14
1,759 평판
안내서 3개를 작성함
USF Tampa, Team 9-1, Blackwell Fall 2014 USF Tampa, Team 9-1, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S9G1
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 34
전체 시간: 2,165
