주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Blu Studio Selfie Midframe Replacement
필요한 것
    1. Blu Studio Selfie Midframe Replacement, Rear Cover: 1 단계, 이미지 1개 중 1개
      • Make sure your phone is powered off.
      • Turn the front of the phone away from you.
      • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
      댓글 쓰기
    2. Blu Studio Selfie Midframe Replacement: 2 단계, 이미지 1개 중 1개
      • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
      • Gently apply pressure until you feel the back case pop free of the phone.
      • Continue the previous two steps around the rest of the phone until the case is fully removed.
      댓글 쓰기
    1. Blu Studio Selfie Midframe Replacement, Battery: 3 단계, 이미지 2개 중 1개 Blu Studio Selfie Midframe Replacement, Battery: 3 단계, 이미지 2개 중 2개
      • Identify the crevice at the bottom of the battery.
      • There should be enough space for you to fit your fingernail between the battery and the phone.
      • Gently lift the battery free of the phone.
      댓글 쓰기
    1. Blu Studio Selfie Midframe Replacement, Midframe: 4 단계, 이미지 1개 중 1개
      • Remove all the 4mm Phillips #000 screws from the midframe.
      댓글 쓰기
    2. Blu Studio Selfie Midframe Replacement: 5 단계, 이미지 1개 중 1개
      • Insert the spudger between the midframe and the display assembly.
      • Gently pry up the midframe.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
      댓글 쓰기
    3. Blu Studio Selfie Midframe Replacement: 6 단계, 이미지 1개 중 1개
      • Where the battery rested before, you will find a small clip that holds down the midframe.
      • After the rest of the midframe is detached, from the phone place the flat end of the spudger beneath the clip.
      • Gently lift up on the clip until it comes free.
      • Remove the midframe from the phone.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Samuel McCandless
회원 가입일: 01/20/16
170 평판
안내서 1개를 작성함
USF Tampa, Team 10-1, Remmell Spring 2016 USF Tampa, Team 10-1, Remmell Spring 2016 회원
USFT-REMMELL-S16S10G1
4 회원들
안내서 42개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 10
전체 시간: 727
