주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Blue Yeti Disassembly
필요한 것
    1. Blue Yeti Disassembly, Retrieve parts and Item and Note 3 Screws on the bottom: 1 단계, 이미지 3개 중 1개 Blue Yeti Disassembly, Retrieve parts and Item and Note 3 Screws on the bottom: 1 단계, 이미지 3개 중 2개 Blue Yeti Disassembly, Retrieve parts and Item and Note 3 Screws on the bottom: 1 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • First remove the Rubber inside the screwable mount area. This can easily be done with a small screw driver tip or Tweezers. From here you can remove the 3 screws using a #1 Phillips head.
      댓글 쓰기
    2. Blue Yeti Disassembly, Removal of the exterior buttons: 2 단계, 이미지 1개 중 1개
      • The 4 exterior buttons can be removed with any force such as fingers or any form of pliers. I used my fingers to remove and pull the buttons from their button placement. You will notice there is a lot of give from the mesh and the body.
      댓글 쓰기
    3. Blue Yeti Disassembly, Remove the Main circuits from the housing: 3 단계, 이미지 3개 중 1개 Blue Yeti Disassembly, Remove the Main circuits from the housing: 3 단계, 이미지 3개 중 2개 Blue Yeti Disassembly, Remove the Main circuits from the housing: 3 단계, 이미지 3개 중 3개
      • On this step, you can easily and carefully pull the entire mic mechanism from the protective housing. On the bottom you will see where the Audio port and USB port are if you need to replace them.
      댓글 쓰기
    4. Blue Yeti Disassembly, Removing the Mic condenser from the Mic Mesh: 4 단계, 이미지 2개 중 1개 Blue Yeti Disassembly, Removing the Mic condenser from the Mic Mesh: 4 단계, 이미지 2개 중 2개
      • If you look toward the mesh and the circuits you will see that it is held by 4x #0 Phillips screws. Carefully remove these and the entire cap will come from the board. There are 3 sets of wires, 1 per condenser. You will notice that they are pointed sideways, making this microphone a side condenser, not a face-pointed one.
      댓글 쓰기
    5. Blue Yeti Disassembly, The Condensers: 5 단계, 이미지 3개 중 1개 Blue Yeti Disassembly, The Condensers: 5 단계, 이미지 3개 중 2개 Blue Yeti Disassembly, The Condensers: 5 단계, 이미지 3개 중 3개
      • As seen in the picture, this Microphone cap comes with a internal foam guard to protect the three internal mic condensers. These point outward to the side of the mic making this mic more useful from the side and not pointed at the users itself.
      댓글 쓰기
    6. Blue Yeti Disassembly, Disconnecting the Mic Condensers: 6 단계, 이미지 1개 중 1개
      • If you need to disconnect the microphone cap from the board, pay close attention to the connections.
      • There are 3 condenser, therefore 3 pairs of wires connect to the board, each with their own wire color (black & white, black & red and black & blue)
      • Pick a position from where to look at the board and take notes of the position of each connector. This is important, since it will directly affect the PATTERN MODES selected in the back side of the mic.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 34명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Kevin Jones
회원 가입일: 11/27/12
1,332 평판
안내서 2개를 작성함
31가이드 댓글
And what if i want to do the opposite?
For example, you removed the down part of the yeti, I wanna remove just the top. How can I do that?
Dino - 답글 공유
You have to remove the bottom to unscrew the top from the inside.
Kevin Jones - 답글 공유
this is a bit of a long shot. but any idea on a replacement part# / source for the 3.5mm barrel jack on one of these?
Joe Romo - 답글 공유
Try searching on e.g. ebay for “3 pin pcb mount female 3.5mm jack”
The plug is a standard part, so it should be readily available. I replaced my plug with a scavanged part that I happened to have on hand!
Anton - 답글 공유
@ Joe
Sorry I don’t.
Kevin Jones - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 21
지난 7일: 118
지난 30일: 553
전체 시간: 69,467
