주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Body Panel Removal
필요한 것
    1. Body Panel Removal, Remove film door: 1 단계, 이미지 1개 중 1개
      • Push down the latch to release the film door.
      댓글 쓰기
    2. Body Panel Removal, Remove top cover screws: 2 단계, 이미지 3개 중 1개 Body Panel Removal, Remove top cover screws: 2 단계, 이미지 3개 중 2개 Body Panel Removal, Remove top cover screws: 2 단계, 이미지 3개 중 3개
      • Remove two 7.5 mm #00 screws.
      • Remove one 9.0 mm #00 screw.
      • Remove one 13.5 mm #00 screw from inside the battery compartment.
      댓글 쓰기
    3. Body Panel Removal, Remove top cover screws: 3 단계, 이미지 3개 중 1개 Body Panel Removal, Remove top cover screws: 3 단계, 이미지 3개 중 2개 Body Panel Removal, Remove top cover screws: 3 단계, 이미지 3개 중 3개
      • Push the button to pop up the flash.
      • Remove one 3.5 mm #00 screw.
      • Remove one 5.5 mm #00 screw.
      댓글 쓰기
    4. Body Panel Removal, Lift top cover: 4 단계, 이미지 1개 중 1개
      • Carefully lift the top cover away from the body to access wired connections.
      • The top cover is still connected in several locations.
      댓글 쓰기
    5. Body Panel Removal, Access flash connections: 5 단계, 이미지 2개 중 1개 Body Panel Removal, Access flash connections: 5 단계, 이미지 2개 중 2개
      • Peel back the corner of the rubber grip.
      • Remove the small plastic cover.
      • Be careful not to short the wires before the flash capacitors have been properly discharged.
      댓글 쓰기
    6. Body Panel Removal, Discharge flash capacitors: 6 단계, 이미지 1개 중 1개
      • Use a 1kΩ-10kΩ high power resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
      • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
      댓글 쓰기
    7. Body Panel Removal, Disconnect right flex cable: 7 단계, 이미지 1개 중 1개
      • Carefully lift the sides of the white latch.
      • Hold the flex PCB on the camera body in place as you lift to prevent damaging the flex.
      댓글 쓰기
    8. Body Panel Removal, Disconnect left flex cable: 8 단계, 이미지 1개 중 1개
      • Desolder the red wire.
      댓글 쓰기
    9. Body Panel Removal, Desolder flash connections: 9 단계, 이미지 2개 중 1개 Body Panel Removal, Desolder flash connections: 9 단계, 이미지 2개 중 2개
      • Desolder blue, black, brown and green wires.
      • Remove the loose shim washer if present.
      댓글 쓰기
    10. Body Panel Removal, Desolder the flash flex cable: 10 단계, 이미지 2개 중 1개 Body Panel Removal, Desolder the flash flex cable: 10 단계, 이미지 2개 중 2개
      • Remove the piece of cellophane tape covering the flex connections.
      • Desolder flex connetions.
      댓글 쓰기
    1. Body Panel Removal, Remove bottom cover: 11 단계, 이미지 3개 중 1개 Body Panel Removal, Remove bottom cover: 11 단계, 이미지 3개 중 2개 Body Panel Removal, Remove bottom cover: 11 단계, 이미지 3개 중 3개
      • Use isopropyl alcohol to soften the adhesive under the country plate and remove.
      • Remove one 5mm #00 screw.
      • Remove one 7.5mm #00 screw.
      • Remove two 4.5mm #00 screws.
      • Remove one 5.5mm #00 screw.
      • Remove the plastic frame around the accessory grip contacts.
      • Reassembly Note: The camera can be checked for functionality at this point. Install the rear door, insert a fresh pair of batteries and try to fire the shutter.
      댓글 쓰기
    2. Body Panel Removal, Remove front left cover: 12 단계, 이미지 1개 중 1개
      • Remove one 4.0 mm #00 screw.
      • Remove left cover.
      댓글 쓰기
    3. Body Panel Removal, Remove front cover: 13 단계, 이미지 1개 중 1개
      • Remove front cover.
      댓글 쓰기
    4. Body Panel Removal, Unscrew front right cover: 14 단계, 이미지 3개 중 1개 Body Panel Removal, Unscrew front right cover: 14 단계, 이미지 3개 중 2개 Body Panel Removal, Unscrew front right cover: 14 단계, 이미지 3개 중 3개
      • Remove one 6.0 mm #00 screw.
      • Remove two 3.5 mm #00 screws.
      • Remove one 5.0 mm #00 screw.
      • Remove the strap lug.
      댓글 쓰기
    5. Body Panel Removal, Remove the front right cover: 15 단계, 이미지 1개 중 1개
      • Carefully pull the right panel away from the body. It is still attached.
      • Desolder the flex connections.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Sam Gustafson
회원 가입일: 09/01/22
14,444 평판
안내서 78개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 27
전체 시간: 619
