주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Boogie Board Rip Copper Button Plate Replacement
필요한 것
  1. Boogie Board Rip Copper Button Plate Replacement, Accessing the internal components: 1 단계, 이미지 2개 중 1개 Boogie Board Rip Copper Button Plate Replacement, Accessing the internal components: 1 단계, 이미지 2개 중 2개
    • On the back of the device, remove the four 3/8" Torx head screws using the T-6 Torx bit.
    • A Torx bit is the piece that is inserted into a bit driver, also known as a screw driver.
    댓글 쓰기
  2. Boogie Board Rip Copper Button Plate Replacement: 2 단계, 이미지 3개 중 1개 Boogie Board Rip Copper Button Plate Replacement: 2 단계, 이미지 3개 중 2개 Boogie Board Rip Copper Button Plate Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the stylus if it is in the housing at the top of the device.
    • Turn the device so you are looking at it from the top down.
    • Using your thumbs on each wall of the stylus housing, open the frame of the device by gently pulling the two sides apart.
    댓글 쓰기
  3. Boogie Board Rip Copper Button Plate Replacement: 3 단계, 이미지 3개 중 1개 Boogie Board Rip Copper Button Plate Replacement: 3 단계, 이미지 3개 중 2개 Boogie Board Rip Copper Button Plate Replacement: 3 단계, 이미지 3개 중 3개
    • Insert a spudger into the seam between the front and back plates of the frame. Unsnap the snaps around the entire frame of the device.
    • Remove the front face plate by pulling it straight up.
    • The unlock switch on the device's side might come off while undoing the internal snaps or removing the face plate. This is perfectly normal.
    댓글 쓰기
  4. Boogie Board Rip Copper Button Plate Replacement: 4 단계, 이미지 2개 중 1개 Boogie Board Rip Copper Button Plate Replacement: 4 단계, 이미지 2개 중 2개
    • Use a spudger (or gently bend the back plate of the device) to unsnap the snaps holding the screen in place.
    댓글 쓰기
  5. Boogie Board Rip Copper Button Plate Replacement: 5 단계, 이미지 2개 중 1개 Boogie Board Rip Copper Button Plate Replacement: 5 단계, 이미지 2개 중 2개
    • With a spudger, press against the lip of the connector closest to the wires to remove the battery connector from the motherboard.
    댓글 쓰기
  6. Boogie Board Rip Copper Button Plate Replacement: 6 단계, 이미지 2개 중 1개 Boogie Board Rip Copper Button Plate Replacement: 6 단계, 이미지 2개 중 2개
    • Gently lift the motherboard with a spudger or small object by inserting it in the seam between the back frame and the motherboard.
    • Remove the battery hidden behind the motherboard.
    댓글 쓰기
  7. Boogie Board Rip Copper Button Plate Replacement, Copper Button Plate: 7 단계, 이미지 2개 중 1개 Boogie Board Rip Copper Button Plate Replacement, Copper Button Plate: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers gently go around the edges of the copper plate to remove the adhesive.
    댓글 쓰기
  8. Boogie Board Rip Copper Button Plate Replacement: 8 단계, 이미지 2개 중 1개 Boogie Board Rip Copper Button Plate Replacement: 8 단계, 이미지 2개 중 2개
    • Use tweezers to grip the outer edge of the copper plate and lift the button straight off.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Gareth
회원 가입일: 09/09/14
360 평판
안내서 3개를 작성함
CSU Fullerton, Team 2-6, Bruce Fall 2014 CSU Fullerton, Team 2-6, Bruce Fall 2014 회원
CSUF-BRUCE-F14S2G6
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 37
전체 시간: 2,990
