주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Boosted Board 1st Generation Belts Replacement
필요한 것
    1. Boosted Board 1st Generation Belts Replacement, Rear Wheels: 1 단계, 이미지 2개 중 1개 Boosted Board 1st Generation Belts Replacement, Rear Wheels: 1 단계, 이미지 2개 중 2개
      • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
      • Do Not Remove the Screws.
      댓글 쓰기
    2. Boosted Board 1st Generation Belts Replacement: 2 단계, 이미지 1개 중 1개
      • Compress the motor mount back towards the wheel.
      • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
      • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
      댓글 쓰기
    3. Boosted Board 1st Generation Belts Replacement: 3 단계, 이미지 2개 중 1개 Boosted Board 1st Generation Belts Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the axel nut with a 1/2" socket wrench
      댓글 쓰기
    4. Boosted Board 1st Generation Belts Replacement: 4 단계, 이미지 3개 중 1개 Boosted Board 1st Generation Belts Replacement: 4 단계, 이미지 3개 중 2개 Boosted Board 1st Generation Belts Replacement: 4 단계, 이미지 3개 중 3개
      • Rotate and pull counterclockwise until the wheel comes off the axle completely.
      • The front washer will come off with the wheel.
      • Remove the back washer from the axle.
      • Replacing the wheel requires the bearings to be switched into the new wheel.
      댓글 쓰기
    1. Boosted Board 1st Generation Belts Replacement, Belts: 5 단계, 이미지 3개 중 1개 Boosted Board 1st Generation Belts Replacement, Belts: 5 단계, 이미지 3개 중 2개 Boosted Board 1st Generation Belts Replacement, Belts: 5 단계, 이미지 3개 중 3개
      • Compress the motor mount back .
      • Slide the belt off the axle
      댓글 쓰기
    2. Boosted Board 1st Generation Belts Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the two hex screws.
      • Remove the front hex screw.
      • When removing the Front hex screw, hold the motor mount and the truck together.
      • The springs inside the motor mount will push the motor out of the casing if they are not held together.
      댓글 쓰기
    3. Boosted Board 1st Generation Belts Replacement: 7 단계, 이미지 3개 중 1개 Boosted Board 1st Generation Belts Replacement: 7 단계, 이미지 3개 중 2개 Boosted Board 1st Generation Belts Replacement: 7 단계, 이미지 3개 중 3개
      • Making sure to hold the motor and truck together, lift off the belt casing and take off the belt.
      • Do Not let go of the motor and truck until the new belt is on and the Front hex screw is tightened securely.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Emily Imfeld
회원 가입일: 10/06/16
532 평판
안내서 4개를 작성함
Cal Poly, Team 15-7, Livingston Fall 2016 Cal Poly, Team 15-7, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G7
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 39
전체 시간: 2,056
