주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Bosch PS21 Motor Replacement
필요한 것
    1. Bosch PS21 Motor Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Pinch the two release tabs on the sides of the battery, and slide the battery out.
      댓글 쓰기
    1. Bosch PS21 Motor Replacement, Motor: 2 단계, 이미지 2개 중 1개 Bosch PS21 Motor Replacement, Motor: 2 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      $3.99
      • After removing the battery pack, locate the clip that connects the two halves of the outer casing shown in the picture. Remove the clip using angled tweezers or a similar tool. Save the clip for reassembly.
      댓글 쓰기
    2. Bosch PS21 Motor Replacement: 3 단계, 이미지 1개 중 1개
      • Locate the eight 5.5 mm screws as shown in the picture.
      • Remove each screw using a small Phillips head screw driver. Save all the screws for reassembly.
      댓글 쓰기
    3. Bosch PS21 Motor Replacement: 4 단계, 이미지 2개 중 1개 Bosch PS21 Motor Replacement: 4 단계, 이미지 2개 중 2개
      • Starting at the rear of the drill, use a wedge to separate the two halves of the outer case at the parting line.
      댓글 쓰기
    4. Bosch PS21 Motor Replacement: 5 단계, 이미지 2개 중 1개 Bosch PS21 Motor Replacement: 5 단계, 이미지 2개 중 2개
      • The motor and trigger assembly are connected by two wires. Do not pull or put tension on these wires.
      • Lift up the metal tab as shown in the first picture to free the trigger assembly.
      • Gently dislodge the motor and trigger assembly from the drill case. Remove the components as one piece, shown in the second picture.
      댓글 쓰기
    5. Bosch PS21 Motor Replacement: 6 단계, 이미지 3개 중 1개 Bosch PS21 Motor Replacement: 6 단계, 이미지 3개 중 2개 Bosch PS21 Motor Replacement: 6 단계, 이미지 3개 중 3개
      • Be sure to not grip the pliers too firmly, as it could cause damage to the wire connectors.
      • Firmly secure the motor assembly in place. Using a set of pliers, carefully pull the black wire connector away from the motor. Repeat this action with the red wire connector.
      • The wire connections on the motor are color coded, matching the color wire that connects there.
      댓글 쓰기
    6. Bosch PS21 Motor Replacement: 7 단계, 이미지 3개 중 1개 Bosch PS21 Motor Replacement: 7 단계, 이미지 3개 중 2개 Bosch PS21 Motor Replacement: 7 단계, 이미지 3개 중 3개
      • Once the wires have been disconnected, separate the trigger mechanism from the motor assembly.
      • Place your hands on each end of mechanism and carefully pull apart the assembly in order to separate the gearbox from the motor.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Daniel Sebastian
회원 가입일: 02/15/16
133 평판
안내서 1개를 작성함
IUPUI, Team 1-2, Harley Spring 2016 IUPUI, Team 1-2, Harley Spring 2016 회원
IUPUI-HARLEY-S16S1G2
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 41
전체 시간: 3,842
