소개
Use this guide to free a stuck dispenser drawer on a Bosch washing machine. The dispenser drawer, detergent drawer, or detergent dispenser holds detergent and fabric softener, and it can jam if the fabric softener level indicator is stuck or installed incorrectly. This procedure was written with a Bosch Serie 4 washing machine and should also apply to Bosch Serie 6 models, though other Bosch models may have small differences.
필요한 것
1 단계 Prepare the washer
Close the water supply if you plan to scrub heavily or leave the dispenser area open for a while.
Pull the dispenser drawer gently until it stops.
3 단계 Remove the drawer fascia
Use your fingers to feel the two clips on either side of the drawer fascia.
Squeeze both clips toward you and lift the fascia upward to release it.
Set the fascia aside where it won't be stepped on.
4 단계 Free the level indicator
Use a flat-blade knife to press the fabric softener level indicator downward through the opening.
Press only hard enough to clear the blockage.
Slide the drawer straight out once the indicator is free.
5 단계 Refit the fascia
Align the fascia with the front of the drawer.
Slide the fascia down into the two clips until it clicks into place.
6 단계 Clean the drawer
Remove the fabric softener level indicator from the drawer.
Use a brush and hot water mixed with dish soap to scrub under the indicator.
Scrub all crevices and the inside of the dispenser drawer.
Rinse or wipe away the loosened residue until the drawer is clean.
8 단계 Scrub the internal compartment
Use a brush, hot water, and dish soap to scrub the dispenser compartment.
Scrub away the detergent residue, fabric softener buildup, mold, and residue.
Use a small sponge to wipe away loose residue if needed.
9 단계 Clear the roof holes
Check the holes in the roof of the dispenser compartment.
Use a small brush to clear any blocked roof holes.
Use a small bit of wire if a small brush doesn't fit.
Wipe the area with a cloth after the holes are clear.
10 단계 Reinstall the drawer
Align the dispenser drawer with the grooves in the dispenser opening.
Press down on the drawer release button and slide the drawer fully home.
Open and close the drawer to make sure it slides smoothly.
11 단계 Clean the door seal
Open the washer door and inspect the door seal seal.
Remove any hair or debris from the seal.
Make sure the drainage holes in the seal are clear.
Wipe the seal and drainage holes with a cloth.
The dispenser drawer should now slide freely, and the drawer and internal compartment should be clean. Keep the drawer and door slightly open between washes to help prevent mold, odors, and future jams. Repair didn't go as planned? Ask our Answers community for help.
