주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Bose SoundLink Color Battery Replacement
필요한 것
    1. Bose SoundLink Color Battery Replacement, Outer Casing: 1 단계, 이미지 2개 중 1개 Bose SoundLink Color Battery Replacement, Outer Casing: 1 단계, 이미지 2개 중 2개
      • Four round, plastic plugs are located on the back of the device.
      • Using a metal spudger, carefully pry up the plastic covers.
      • The covers are all glued on, so be careful not to scar the casing when prying them off. If possible, use a spudger or plastic opening tool to remove them.
      댓글 쓰기
    2. Bose SoundLink Color Battery Replacement: 2 단계, 이미지 2개 중 1개 Bose SoundLink Color Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the four 1.8 cm-long T15 Torx Security screws from the outer case.
      • Some of these use T15 "Star" 5-point Torx security screws instead of the more common 6-point ones.
      댓글 쓰기
    3. Bose SoundLink Color Battery Replacement: 3 단계, 이미지 2개 중 1개 Bose SoundLink Color Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Carefully open up the casing.
      • The top button pad may need to be re-glued upon installing the new casing.
      댓글 쓰기
    1. Bose SoundLink Color Battery Replacement, Battery: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Carefully remove the battery using a pair of tweezers.
      • Lift the inner assembly from the outer casing.
      댓글 쓰기
    2. Bose SoundLink Color Battery Replacement: 5 단계, 이미지 1개 중 1개
      • Partially cut the battery cover on the side paying attention to do not damage the circuit or the battery. Cut the cover just enough to remove it, try to not damage it too much as it is going to be reused.
      댓글 쓰기
    3. Bose SoundLink Color Battery Replacement: 6 단계, 이미지 3개 중 1개 Bose SoundLink Color Battery Replacement: 6 단계, 이미지 3개 중 2개 Bose SoundLink Color Battery Replacement: 6 단계, 이미지 3개 중 3개
      • Desolder the battery leads from the PCB and remove the battery.
      댓글 쓰기
    4. Bose SoundLink Color Battery Replacement: 7 단계, 이미지 1개 중 1개
      • I opted for a Panasonic NCR18650B, choose the version with solder tabs, otherwise it will be a pain to solder wires on the battery and you'll probably go out from the factory dimensions. From the benchmarks it looks like a very good battery, time will tell.
      • Fit the new battery, cut the leads to the needed length, pay attention to polarity. You may need to enlarge leads holes in the plastic case with a cutter to let standard battery leads thru.
      댓글 쓰기
    5. Bose SoundLink Color Battery Replacement: 8 단계, 이미지 1개 중 1개
      • Put back the sponge cover, it is necessary to avoid vibrations and to keep the thing firmly in place.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 102명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Michael Thorn
회원 가입일: 03/31/16
557 평판
안내서 3개를 작성함
66가이드 댓글
Any recommendations where to pick up/order a replacement battery from?
Rob Miller - 답글 공유
See the link in the description, it is available thru Amazon
Giacomo di ciocco - 답글 공유
Has anyone found where to order battery from?
amitos80 - 답글 공유
Put battery part number in google and search it on ebay. It will come up with your replacement
Ron Emerson - 답글 공유
Mine still works fine, but I'd like to know like the others here where to get a battery that will work as a replacement.
chandlerwebb - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 18
지난 7일: 199
지난 30일: 1,001
전체 시간: 230,796
