주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Bose SoundLink Color Speaker Replacement
필요한 것
    1. Bose SoundLink Color Speaker Replacement, Outer Casing: 1 단계, 이미지 2개 중 1개 Bose SoundLink Color Speaker Replacement, Outer Casing: 1 단계, 이미지 2개 중 2개
      • Four round, plastic plugs are located on the back of the device.
      • Using a metal spudger, carefully pry up the plastic covers.
      • The covers are all glued on, so be careful not to scar the casing when prying them off. If possible, use a spudger or plastic opening tool to remove them.
      댓글 쓰기
    2. Bose SoundLink Color Speaker Replacement: 2 단계, 이미지 2개 중 1개 Bose SoundLink Color Speaker Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the four 1.8 cm-long T15 Torx Security screws from the outer case.
      • Some of these use T15 "Star" 5-point Torx security screws instead of the more common 6-point ones.
      댓글 쓰기
    3. Bose SoundLink Color Speaker Replacement: 3 단계, 이미지 2개 중 1개 Bose SoundLink Color Speaker Replacement: 3 단계, 이미지 2개 중 2개
      • Carefully open up the casing.
      • The top button pad may need to be re-glued upon installing the new casing.
      댓글 쓰기
    1. Bose SoundLink Color Speaker Replacement, Speaker: 4 단계, 이미지 2개 중 1개 Bose SoundLink Color Speaker Replacement, Speaker: 4 단계, 이미지 2개 중 2개
      • Lift up the retaining flap on the button cable ZIF connector.
      • Pull the button cable straight out of the connector.
      • Remove the inner assembly.
      댓글 쓰기
    2. Bose SoundLink Color Speaker Replacement: 5 단계, 이미지 1개 중 1개
      • The speakers are on the front of the inner assembly.
      • Using the Phillips head screwdriver, unscrew the four 1.3 cm screws holding the speaker that will be replaced.
      댓글 쓰기
    3. Bose SoundLink Color Speaker Replacement: 6 단계, 이미지 2개 중 1개 Bose SoundLink Color Speaker Replacement: 6 단계, 이미지 2개 중 2개
      • Three screws hold the printed circuit board.
      • Using the Phillips head screwdriver, unscrew the three 1.2 cm screws.
      댓글 쓰기
    4. Bose SoundLink Color Speaker Replacement: 7 단계, 이미지 2개 중 1개 Bose SoundLink Color Speaker Replacement: 7 단계, 이미지 2개 중 2개
      • Desolder each the three pins connecting the speaker to the motherboard.
      • Carefully lift the motherboard with a spudger to ensure that each pin desolders.
      • Work carefully. Prying too hard may cause damage to the board.
      댓글 쓰기
    5. Bose SoundLink Color Speaker Replacement: 8 단계, 이미지 1개 중 1개
      • Push the speaker through the front of the inner assembly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 21명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Brett Horstketter
회원 가입일: 03/31/16
2,906 평판
안내서 1개를 작성함
13가이드 댓글
Thanks for this tear down. Never thought that it looks like this on the inside. My battery is kind off aging, bought the unit 7 months ago. Local Bose dealer said battery cost half of this speaker. I hope there is a cheaper alternative.
vintiglao22 - 답글 공유
You can unsolder the battery and replace with a standard unprotected 18650 cell it literally costs 7$ for a high quality sony or panasonic or samsung cell. The protection and charging circuit is included in the speaker motherboard just make sure you resolder with the proper polarity.
swiftink - 답글 공유
Como ago para traducir cada
luis beltran - 답글 공유
Speaker looks like a 18650 lithium ion- from the pictures here.
DR Paquette - 답글 공유
Does anybody know where one could order a spare speaker for this device?
sebastiansebisilva - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 49
지난 30일: 178
전체 시간: 36,266
