주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Bose SoundLink III Charging Port Replacement
필요한 것
    1. Bose SoundLink III Charging Port Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
      • The rubber pads should have enough adhesive to stick when you reassemble them at the end. If not, however, you may need your own adhesive.
      댓글 쓰기
    2. Bose SoundLink III Charging Port Replacement: 2 단계, 이미지 2개 중 1개 Bose SoundLink III Charging Port Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
      • These screws may be difficult to remove. If necessary, use a lever for extra torque.
      • Remove the bottom panel.
      댓글 쓰기
    3. Bose SoundLink III Charging Port Replacement: 3 단계, 이미지 1개 중 1개
      • Flip the rear panel back to allow access to the SoundLink's battery.
      댓글 쓰기
    4. Bose SoundLink III Charging Port Replacement: 4 단계, 이미지 2개 중 1개 Bose SoundLink III Charging Port Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the two 12.5 mm Phillips #2 screws from the sides of the battery.
      댓글 쓰기
    1. Bose SoundLink III Charging Port Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
      • Gently peel back the adhesive padding on either side of the inner back panel.
      • The adhesive for these pads is powerful, but you may require new adhesive if the original begins to fail.
      댓글 쓰기
    2. Bose SoundLink III Charging Port Replacement: 6 단계, 이미지 2개 중 1개 Bose SoundLink III Charging Port Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the four 12.5 mm Phillips #2 screws mounting the outer case.
      • Slide off the outer case.
      댓글 쓰기
    3. Bose SoundLink III Charging Port Replacement: 7 단계, 이미지 1개 중 1개
      • Remove four screws from each of the four speakers (16 screws total) using a Torx #10 screwdriver.
      • All screws (excluding the two middle screws on the right side) are 12.5 mm in length. The aforementioned middle screws are 21 mm.
      댓글 쓰기
    4. Bose SoundLink III Charging Port Replacement: 8 단계, 이미지 2개 중 1개 Bose SoundLink III Charging Port Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the two 12.5 mm screws which mount the top panel using a Phillips #2 screwdriver.
      • Now you should be able to lift the top panel off.
      댓글 쓰기
    5. Bose SoundLink III Charging Port Replacement: 9 단계, 이미지 2개 중 1개 Bose SoundLink III Charging Port Replacement: 9 단계, 이미지 2개 중 2개
      • Use a metal spudger to pry the device apart. You must use a metal spudger because of the great force necessary to pry it apart.
      • The circuitry for the buttons on the top panel may be found underneath, so use caution not to damage it.
      댓글 쓰기
    6. Bose SoundLink III Charging Port Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the 12.5 mm screw mounting the motherboard using a Philips #2 screwdriver.
      댓글 쓰기
    7. Bose SoundLink III Charging Port Replacement: 11 단계, 이미지 1개 중 1개
      • Gently disconnect the three cables connected to the motherboard.
      • Remove the motherboard from the device.
      댓글 쓰기
    1. Bose SoundLink III Charging Port Replacement, Charging Port: 12 단계, 이미지 2개 중 1개 Bose SoundLink III Charging Port Replacement, Charging Port: 12 단계, 이미지 2개 중 2개
      • Remove the two 12.5 mm screws on either side of the charging port using a Torx T10 screwdriver.
      댓글 쓰기
    2. Bose SoundLink III Charging Port Replacement: 13 단계, 이미지 2개 중 1개 Bose SoundLink III Charging Port Replacement: 13 단계, 이미지 2개 중 2개
      • Gently unplug the cable connecting the charging port.
      • Now the charging port should be fully detached and ready for replacement.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Dakoda Sanders
회원 가입일: 02/04/16
1,669 평판
안내서 4개를 작성함
USF Tampa, Team 3-2, Wollert Spring 2016 USF Tampa, Team 3-2, Wollert Spring 2016 회원
USFT-WOLLERT-S16S3G2
4 회원들
안내서 18개를 작성함
15가이드 댓글
Hello, This is an excellent resource. One thing, you did not say, or I did not see, where to purchase the actual usb port. Where can I locate one and this would be for a Bose Soundlink II.
Thank you,
Jim
jp7868@gmail.com
James Patrick - 답글 공유
HI, thanks a lot for the instructions, any idea where i acn purchase the charging port full part
thanks
Carlos
Carlos Gallardo - 답글 공유
I would like to know where i can buy the replacement part
Jeroen Knip - 답글 공유
Also would love to know where to purchase the required replacement MicroUSB Port. I'm searching and if I find anything compatible I will contact anyone else who posts to this thread.
Driftless Repair - 답글 공유
Where can you get the part?
Shari - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 26
지난 30일: 129
전체 시간: 21,323
