주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Bose SoundTouch 20 Motherboard Replacement
필요한 것
  1. Bose SoundTouch 20 Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 Bose SoundTouch 20 Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
    • Remove the (6) six 1.5mm Phillips screws holding on the bottom cover of the speaker using a Phillips #0 screwdriver.
    • Lift the cover straight up and set the cover aside.
    댓글 쓰기
  2. Bose SoundTouch 20 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Bose SoundTouch 20 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Gently pull the white ribbon from the connector on the top side of the power board.
    • Make sure to pull straight back so you don't bend or damage the ribbon.
    댓글 쓰기
  3. Bose SoundTouch 20 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Bose SoundTouch 20 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the (4) four 1.5 cm screws connecting the power board to the speaker.
    • Remove the (2) two 1 cm screws connecting the power board to the speaker.
    • Gently lift the board up.
    • When lifting the board, be careful of the two ribbons located underneath the board. Don't lift the board straight up, instead tilt it towards the cables. As shown in picture 2.
    댓글 쓰기
  4. Bose SoundTouch 20 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Bose SoundTouch 20 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the white cable by pressing on the side of the connector with a tab and pulling backwards.
    댓글 쓰기
  5. Bose SoundTouch 20 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Bose SoundTouch 20 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Gently pull the thinner white ribbon towards the center of the board.
    • Pull straight down to prevent bending or damaging the ribbon.
    • Squeeze the plastic sides of the plug and pull straight down to remove this ribbon.
    • Remove the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Daniel Talanga
회원 가입일: 09/28/17
381 평판
안내서 2개를 작성함
USF Tampa, Team S11-G3, Passmore Fall 2017 USF Tampa, Team S11-G3, Passmore Fall 2017 회원
USFT-PASSMORE-F17S11G3
4 회원들
안내서 11개를 작성함
8가이드 댓글
But how do I purchase a new motherboard?
Donald Weber - 답글 공유
Thank you for excellent information and instruction. Can you please send some link to order a new motherboard?
leo.benjamin - 답글 공유
Thank you for the tutorial. How do I purchase a new motherboard ?
benjamin lozano - 답글 공유
Any known place to purchase a replacement board?
Marceli Palak - 답글 공유
Any luck with a place to purchase a replcement board ?
Henry - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 20
지난 30일: 94
전체 시간: 10,433
