주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Bose Soundlink Flex Battery Replacement
필요한 것
    1. Bose Soundlink Flex Battery Replacement, Grille: 1 단계, 이미지 1개 중 1개
      • Use a heat gun to warm up the device.
      • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
      댓글 쓰기
    2. Bose Soundlink Flex Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Use an iFixit opening tool to pop off the eight clips on the grille.
      • Be patient and do not rush this process as you may otherwise damage the device.
      댓글 쓰기
    3. Bose Soundlink Flex Battery Replacement: 3 단계, 이미지 2개 중 1개 Bose Soundlink Flex Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Once the clips have been released, the only thing holding the grille on is glue.
      • Apply minimal force and the grille should pop right off the device.
      • Reheat the device to warm up the glue if there is difficulty in removing.
      댓글 쓰기
    1. Bose Soundlink Flex Battery Replacement, Battery: 4 단계, 이미지 3개 중 1개 Bose Soundlink Flex Battery Replacement, Battery: 4 단계, 이미지 3개 중 2개 Bose Soundlink Flex Battery Replacement, Battery: 4 단계, 이미지 3개 중 3개
      • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
      • Lift the driver out, being cautious of the wires still connected to the device.
      댓글 쓰기
    2. Bose Soundlink Flex Battery Replacement: 5 단계, 이미지 3개 중 1개 Bose Soundlink Flex Battery Replacement: 5 단계, 이미지 3개 중 2개 Bose Soundlink Flex Battery Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
      • Pull the back panel off exposing the motherboard.
      댓글 쓰기
    3. Bose Soundlink Flex Battery Replacement: 6 단계, 이미지 2개 중 1개 Bose Soundlink Flex Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the three 1.7 mm screws from the motherboard using a TR6 Torx screwdriver.
      • Remove the single 1.4 mm screw from the motherboard using a TR5 Torx screwdriver.
      댓글 쓰기
    4. Bose Soundlink Flex Battery Replacement: 7 단계, 이미지 3개 중 1개 Bose Soundlink Flex Battery Replacement: 7 단계, 이미지 3개 중 2개 Bose Soundlink Flex Battery Replacement: 7 단계, 이미지 3개 중 3개
      • Take the motherboard out and take note of the battery attached.
      • Remove the insulation and the solder from the wiring.
      • Be careful not to damage the motherboard. Doing so will create a slew of problems for the speaker.
      • Solder the wires of the new battery onto the motherboard.
      • Be cautious when adding the solder to not damage the motherboard or burn yourself.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kalvin Lee
회원 가입일: 03/19/24
625 평판
안내서 3개를 작성함
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 UMass Dartmouth, Team 4-1, Shaddix Spring 2024 회원
UMASSD-SHADDIX-S24S4G1
3 회원들
안내서 31개를 작성함
1가이드 댓글
How do I know which one is the positive and which one is the negative side of my battery connector in soundlink flex ? As I have already removed the old battery only.
SOM SATPATHY - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 22
지난 7일: 121
지난 30일: 453
전체 시간: 8,728
