주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Bose Soundlink Flex Radiator Replacement
필요한 것
  1. Bose Soundlink Flex Radiator Replacement, Grille: 1 단계, 이미지 1개 중 1개
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
    댓글 쓰기
  2. Bose Soundlink Flex Radiator Replacement: 2 단계, 이미지 1개 중 1개
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
    댓글 쓰기
  3. Bose Soundlink Flex Radiator Replacement: 3 단계, 이미지 2개 중 1개 Bose Soundlink Flex Radiator Replacement: 3 단계, 이미지 2개 중 2개
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
    댓글 쓰기
  4. Bose Soundlink Flex Radiator Replacement, Radiator: 4 단계, 이미지 3개 중 1개 Bose Soundlink Flex Radiator Replacement, Radiator: 4 단계, 이미지 3개 중 2개 Bose Soundlink Flex Radiator Replacement, Radiator: 4 단계, 이미지 3개 중 3개
    • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
    • Lift the driver out, being cautious of the wires still connected to the device.
    댓글 쓰기
  5. Bose Soundlink Flex Radiator Replacement: 5 단계, 이미지 2개 중 1개 Bose Soundlink Flex Radiator Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
    댓글 쓰기
  6. Bose Soundlink Flex Radiator Replacement: 6 단계, 이미지 3개 중 1개 Bose Soundlink Flex Radiator Replacement: 6 단계, 이미지 3개 중 2개 Bose Soundlink Flex Radiator Replacement: 6 단계, 이미지 3개 중 3개
    • Pull the backplate off to expose both sides of the radiator.
    댓글 쓰기
  7. Bose Soundlink Flex Radiator Replacement: 7 단계, 이미지 3개 중 1개 Bose Soundlink Flex Radiator Replacement: 7 단계, 이미지 3개 중 2개 Bose Soundlink Flex Radiator Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the four 2.3 mm corner screws using a TR8 Torx screwdriver.
    • Remove the two 1.7 mm screws using a TR6 Torx screwdriver.
    • Follow this step for both radiators.
    댓글 쓰기
  8. Bose Soundlink Flex Radiator Replacement: 8 단계, 이미지 2개 중 1개 Bose Soundlink Flex Radiator Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the radiator and replace with the new radiator.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Monica Silva
회원 가입일: 03/19/24
262 평판
안내서 1개를 작성함
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 UMass Dartmouth, Team 4-1, Shaddix Spring 2024 회원
UMASSD-SHADDIX-S24S4G1
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 54
전체 시간: 983
