주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Bottom Board Removal
필요한 것
    1. Bottom Board Removal, Engage Wired Optical Mouse Top and Outer Shell Removal: 1 단계, 이미지 1개 중 1개
      • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
      댓글 쓰기
    2. Bottom Board Removal: 2 단계, 이미지 1개 중 1개
      • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
      • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
      댓글 쓰기
    3. Bottom Board Removal: 3 단계, 이미지 3개 중 1개 Bottom Board Removal: 3 단계, 이미지 3개 중 2개 Bottom Board Removal: 3 단계, 이미지 3개 중 3개
      • Grab the top shell of the mouse and lift up to remove.
      댓글 쓰기
    4. Bottom Board Removal: 4 단계, 이미지 1개 중 1개
      • The capacitors on this board can release stored electrical energy if touched.
      • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
      댓글 쓰기
    5. Bottom Board Removal: 5 단계, 이미지 2개 중 1개 Bottom Board Removal: 5 단계, 이미지 2개 중 2개
      • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
      댓글 쓰기
    1. Bottom Board Removal, Side Panels: 6 단계, 이미지 2개 중 1개 Bottom Board Removal, Side Panels: 6 단계, 이미지 2개 중 2개
      • Locate the 5 mm silver flat head mounting screws (2) to the left and right of the scroll wheel and remove with the Phillips #1 screwdriver.
      댓글 쓰기
    2. Bottom Board Removal: 7 단계, 이미지 2개 중 1개 Bottom Board Removal: 7 단계, 이미지 2개 중 2개
      • Locate the snaps on the bottom corners of the mouse side panels and pop the indicated snaps out, using a spudger or your fingernail.
      댓글 쓰기
    3. Bottom Board Removal: 8 단계, 이미지 3개 중 1개 Bottom Board Removal: 8 단계, 이미지 3개 중 2개 Bottom Board Removal: 8 단계, 이미지 3개 중 3개
      • Repeat Step 6 for the opposite side panel in order to detach both sides from the base of the mouse.
      댓글 쓰기
    4. Bottom Board Removal: 9 단계, 이미지 2개 중 1개 Bottom Board Removal: 9 단계, 이미지 2개 중 2개
      • Grab the sides of the mouse and lift them up to detach from the base of the mouse.
      댓글 쓰기
    1. Bottom Board Removal, Bottom Board: 10 단계, 이미지 2개 중 1개 Bottom Board Removal, Bottom Board: 10 단계, 이미지 2개 중 2개
      • Pop the scroll wheel out of the snap holding it in place. You can use your finger or a spudger to do so.
      댓글 쓰기
    2. Bottom Board Removal: 11 단계, 이미지 2개 중 1개 Bottom Board Removal: 11 단계, 이미지 2개 중 2개
      • Locate the four 5 mm black flat head screws on the corners of the bottom board.
      • Unscrew these four black screws.
      댓글 쓰기
    3. Bottom Board Removal: 12 단계, 이미지 3개 중 1개 Bottom Board Removal: 12 단계, 이미지 3개 중 2개 Bottom Board Removal: 12 단계, 이미지 3개 중 3개
      • Lift the bottom board up to remove from its mounting posts. This will separate it completely from the bottom panel of the mouse.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
royceeklund
회원 가입일: 01/18/13
115 평판
안내서 3개를 작성함
Cal Poly, Team 18-36, Regan Winter 2013 Cal Poly, Team 18-36, Regan Winter 2013 회원
CPSU-REGAN-W13S18G36
3 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 55
전체 시간: 6,263
