주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Braun Shaver Model 7680 Battery Replacement
필요한 것
  1. Braun Shaver Model 7680 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Soldering is required to install this battery one or two batteries may be required verify how many you need before you order
    댓글 쓰기
  2. Braun Shaver Model 7680 Battery Replacement, Remove bottom cover: 2 단계, 이미지 2개 중 1개 Braun Shaver Model 7680 Battery Replacement, Remove bottom cover: 2 단계, 이미지 2개 중 2개
    • First pry the left side of the cover off, then pry the right side of the cover off before removing. Trying to pry the cover off from only one side will result in breaking the plastic tabs.
    댓글 쓰기
  3. Braun Shaver Model 7680 Battery Replacement, Remove side covers: 3 단계, 이미지 1개 중 1개
    • Pull the side covers off from the bottom, they hinge from the top and will come off freely once you rotate them up and away from the body starting at the bottom.
    댓글 쓰기
  4. Braun Shaver Model 7680 Battery Replacement, Remove screws on back: 4 단계, 이미지 2개 중 1개 Braun Shaver Model 7680 Battery Replacement, Remove screws on back: 4 단계, 이미지 2개 중 2개
    • You will need a T9 hex screw driver.
    댓글 쓰기
    • R17 AA NiMh Battery With Pin Tabs 1650 Mah 1.2V Battery Measures .559" x 1.97", 14.2mm x 50mm
    댓글 쓰기
    • Replacing the batteries will not always repair the shaver, the circuit board may be bad, if the indicator lights on the circuit board do not light up when plugged in the circuit board is most likely bad, you should replace the entire circuit board and battery assembly.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 19명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
mayer
회원 가입일: 01/04/10
690,411 평판
안내서 11개를 작성함
8가이드 댓글
Great tutorial. It was all I needed, since I wasn't sure how to get the case open. Thanks!
mikebailey - 답글 공유
Thanks for the tutorial! Mine had intermittent problem with the on/off switch and I was googling how to open the case. Easy and simple, bets razor I’ve had and not willing to change :D
Tero Kortetmäki - 답글 공유
Thanks for the tutorial… but it is a T8 Torx at least in the Model 7570. I just had to take out the recharchable batteries to get mine working properly again.
A Krueger - 답글 공유
Danke für die übersichtliche Anleitung, hat mir gut geholfen. Die wichtige Frage ist immer:
Wie geht ‘s Gehäuse auf. ?
Garofalo - 답글 공유
Thanks for the guide! Without knowing how to open the case, replacing the battery would have been a lost cause. In my case the batteries were tired. After replacing and recharging them the razor sounds young again and full of pep.
Stephen Spratley - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 21
지난 30일: 147
전체 시간: 25,151
