주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Braven BRV-1M Button Register Replacement
필요한 것
    1. Braven BRV-1M Button Register Replacement, Outer Casing: 1 단계, 이미지 1개 중 1개
      • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
      댓글 쓰기
    2. Braven BRV-1M Button Register Replacement: 2 단계, 이미지 1개 중 1개
      • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
      • A little resistance should be felt, but not enough to bend the spudger.
      댓글 쓰기
    3. Braven BRV-1M Button Register Replacement: 3 단계, 이미지 1개 중 1개
      • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
      댓글 쓰기
    4. Braven BRV-1M Button Register Replacement: 4 단계, 이미지 1개 중 1개
      • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
      댓글 쓰기
    1. Braven BRV-1M Button Register Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
      • To remove the motherboard, proceed to unscrew the 3 Phillips #00 bit type, 13mm long screws located on both sides of the motherboard.
      댓글 쓰기
    2. Braven BRV-1M Button Register Replacement: 6 단계, 이미지 1개 중 1개
      • Then, proceed to unscrew the 5 Phillips #00 bit type, 9mm long screws located on the face of the charging dock.
      댓글 쓰기
    3. Braven BRV-1M Button Register Replacement: 7 단계, 이미지 1개 중 1개
      • Disconnect the two 4-pin auxiliary button register cables connected on both sides of the motherboard.
      댓글 쓰기
    4. Braven BRV-1M Button Register Replacement: 8 단계, 이미지 1개 중 1개
      • Once disconnected, carefully remove the motherboard by pulling upwards.
      댓글 쓰기
    1. Braven BRV-1M Button Register Replacement, Button Register: 9 단계, 이미지 1개 중 1개
      • To remove the button registers, unscrew the two Phillips #00 bit type, 6 mm screws found on both sides of the control registers.
      댓글 쓰기
    2. Braven BRV-1M Button Register Replacement: 10 단계, 이미지 1개 중 1개
      • Carefully remove the control registers from the housing of the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Erik Oliva
회원 가입일: 02/14/18
607 평판
안내서 6개를 작성함
USF Tampa, Team S2-G1, Eyestone Spring 2018 USF Tampa, Team S2-G1, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S2G1
4 회원들
안내서 12개를 작성함
1가이드 댓글
Great guide! Do you know the spec/name of the button registers so that I can purchase a new one to replace a dysfunctional one?
Mason McElvain - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 24
전체 시간: 665
