주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Brother IntelliFax-2840 Control Panel Replacement
필요한 것
    1. Brother IntelliFax-2840 Control Panel Replacement, Automatic Document Feeder: 1 단계, 이미지 1개 중 1개
      • Remove the two 15 mm Phillips #1 screws securing the ADF at the rear of the fax machine.
      댓글 쓰기
    2. Brother IntelliFax-2840 Control Panel Replacement: 2 단계, 이미지 2개 중 1개 Brother IntelliFax-2840 Control Panel Replacement: 2 단계, 이미지 2개 중 2개
      • Gently pull the ADF up and away from the machine.
      댓글 쓰기
    1. Brother IntelliFax-2840 Control Panel Replacement, Control Panel: 3 단계, 이미지 2개 중 1개 Brother IntelliFax-2840 Control Panel Replacement, Control Panel: 3 단계, 이미지 2개 중 2개
      • Gently lift up the control panel.
      댓글 쓰기
    2. Brother IntelliFax-2840 Control Panel Replacement: 4 단계, 이미지 3개 중 1개 Brother IntelliFax-2840 Control Panel Replacement: 4 단계, 이미지 3개 중 2개 Brother IntelliFax-2840 Control Panel Replacement: 4 단계, 이미지 3개 중 3개
      • Use a finger or prying tool to gently pop off the right side control arm (furthest from the handset).
      • Repeat for the left side control arm.
      • You can make this task easier by taking the handset out of the cradle and setting it aside.
      댓글 쓰기
    3. Brother IntelliFax-2840 Control Panel Replacement: 5 단계, 이미지 2개 중 1개 Brother IntelliFax-2840 Control Panel Replacement: 5 단계, 이미지 2개 중 2개
      • Do not attempt to completely remove the control panel yet, as it is still connected by a cable.
      • Lifting from the front edge, gently flip up the control panel.
      댓글 쓰기
    4. Brother IntelliFax-2840 Control Panel Replacement: 6 단계, 이미지 1개 중 1개
      • While supporting the control panel with one hand, remove the three 12.2 mm Phillips #1 screws securing the rear control panel cover.
      댓글 쓰기
    5. Brother IntelliFax-2840 Control Panel Replacement: 7 단계, 이미지 1개 중 1개
      • While still supporting the control panel, use your fingers or a spudger to gently free the two plastic clips securing the rear control panel cover.
      • Slide the rear control panel cover down slightly to free it from the three clips along the upper edge.
      댓글 쓰기
    6. Brother IntelliFax-2840 Control Panel Replacement: 8 단계, 이미지 2개 중 1개 Brother IntelliFax-2840 Control Panel Replacement: 8 단계, 이미지 2개 중 2개
      • Separate the rear control panel cover from the control panel.
      댓글 쓰기
    7. Brother IntelliFax-2840 Control Panel Replacement: 9 단계, 이미지 2개 중 1개 Brother IntelliFax-2840 Control Panel Replacement: 9 단계, 이미지 2개 중 2개
      • Gently pull the control panel cable straight out from its connector.
      • The control panel should now come free.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Geoff Wacker
회원 가입일: 09/30/13
93,026 평판
안내서 88개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 28
지난 30일: 67
전체 시간: 4,694
