주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Brother PT-1010 Keyboard Replacement
필요한 것
    1. Brother PT-1010 Keyboard Replacement, Remove Back Cover: 1 단계, 이미지 1개 중 1개
      • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
      댓글 쓰기
    2. Brother PT-1010 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
      • Remove batteries, cassette tape, and cutter blade.
      댓글 쓰기
    3. Brother PT-1010 Keyboard Replacement, Remove Screws: 3 단계, 이미지 1개 중 1개
      • Use a phillips size #00 screwdriver to unscrew the 5 corner screws circled in the picture.
      댓글 쓰기
    4. Brother PT-1010 Keyboard Replacement, Separate Device: 4 단계, 이미지 1개 중 1개
      • Separate the top of the device from the bottom. Be very cautious when you separate the device, there is a ribbon attaching the top to the bottom.
      댓글 쓰기
    5. Brother PT-1010 Keyboard Replacement, Remove side panels: 5 단계, 이미지 1개 중 1개
      • Remove the two black side panels. They will easily fall out so just move them to the side until you are putting your device back together.
      댓글 쓰기
    6. Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: 6 단계, 이미지 3개 중 1개 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: 6 단계, 이미지 3개 중 2개 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: 6 단계, 이미지 3개 중 3개
      • Using your index finger and thumb, pull out the golden ribbon from the green circuit board.
      댓글 쓰기
    7. Brother PT-1010 Keyboard Replacement, Remove Screws from Circuit Board: 7 단계, 이미지 1개 중 1개
      • Use a phillips size #00 screwdriver to remove the two screws, circled in red, from the green circuit board.
      댓글 쓰기
    8. Brother PT-1010 Keyboard Replacement, Remove Circuit Board: 8 단계, 이미지 1개 중 1개
      • Carefully remove the green circuit board by pulling it straight up. Be careful not to break the LCD cable ribbon that connects the circuit board to the device.
      • The ribbon is very fragile so be careful to break it when pulling up on the circuit board.
      댓글 쓰기
    9. Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: 9 단계, 이미지 3개 중 1개 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: 9 단계, 이미지 3개 중 2개 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: 9 단계, 이미지 3개 중 3개
      • Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Haley Sweet
회원 가입일: 10/30/14
460 평판
안내서 4개를 작성함
Baylor, Team 4-4, Williams Fall 2014 Baylor, Team 4-4, Williams Fall 2014 회원
BU-WILLIAMS-F14S4G4
4 회원들
안내서 4개를 작성함
3가이드 댓글
Hi!
Thanks for this very helpful and detailed set of instructions. One small suggestion - assuming that replacing the keyboard means you need a working one to replace the old one with, you might want to consider adding “Parts: replacement keyboard” instead of “No parts required.”
Cheers,
Maria B
Maria Bitterli - 답글 공유
Please specify what is being replaced. Is the rubber keyboard the part that needs to be replaced?
Sincere Cavalier - 답글 공유
Screen is dull, what to do
Judy Baranczyk - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 36
전체 시간: 3,651
