주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Brother PT-110 Printer Motor Replacement
필요한 것
    1. Brother PT-110 Printer Motor Replacement, Batteries: 1 단계, 이미지 2개 중 1개 Brother PT-110 Printer Motor Replacement, Batteries: 1 단계, 이미지 2개 중 2개
      • Push on the side of the cover, and remove it.
      댓글 쓰기
    2. Brother PT-110 Printer Motor Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the batteries.
      댓글 쓰기
    1. Brother PT-110 Printer Motor Replacement, Back Plate: 3 단계, 이미지 2개 중 1개 Brother PT-110 Printer Motor Replacement, Back Plate: 3 단계, 이미지 2개 중 2개
      • Unscrew the two 9 mm Phillips #1 screws from the top and bottom.
      • Total: 2 x Screws
      댓글 쓰기
    2. Brother PT-110 Printer Motor Replacement: 4 단계, 이미지 1개 중 1개
      • First: To separate the top cover from the body, insert a spudger between the two halves.
      • Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
      • DO NOT PULL HALVES APART. There are wired connections inside that must be disconnected before halves can be fully separated.
      댓글 쓰기
    3. Brother PT-110 Printer Motor Replacement: 5 단계, 이미지 1개 중 1개
      • Gently separate the two covers, ensuring wires are not taut.
      댓글 쓰기
    4. Brother PT-110 Printer Motor Replacement: 6 단계, 이미지 1개 중 1개
      • Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
      댓글 쓰기
    5. Brother PT-110 Printer Motor Replacement: 7 단계, 이미지 2개 중 1개 Brother PT-110 Printer Motor Replacement: 7 단계, 이미지 2개 중 2개
      • Carefully pinch the top of the connector.
      • Pull perpendicular to the device until the wire is disconnected.
      • It may require more force than expected to disconnect the wires.
      댓글 쓰기
    6. Brother PT-110 Printer Motor Replacement: 8 단계, 이미지 3개 중 1개 Brother PT-110 Printer Motor Replacement: 8 단계, 이미지 3개 중 2개 Brother PT-110 Printer Motor Replacement: 8 단계, 이미지 3개 중 3개
      • Unscrew the three 9 mm Phillips #1 screws shown.
      • Total: 3 x Screws
      댓글 쓰기
    1. Brother PT-110 Printer Motor Replacement, Printer Motor: 9 단계, 이미지 1개 중 1개
      • Remove the motor housing.
      댓글 쓰기
    2. Brother PT-110 Printer Motor Replacement: 10 단계, 이미지 2개 중 1개 Brother PT-110 Printer Motor Replacement: 10 단계, 이미지 2개 중 2개
      • Unscrew the two 3 mm Phillips #1 screws from the motor housing.
      • Total: 2 x Screws
      댓글 쓰기
    3. Brother PT-110 Printer Motor Replacement: 11 단계, 이미지 1개 중 1개
      • Remove the motor.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Kimberly Larsen
회원 가입일: 09/28/16
279 평판
안내서 5개를 작성함
IUPUI, Team 1-1, Harley Fall 2016 IUPUI, Team 1-1, Harley Fall 2016 회원
IUPUI-HARLEY-F16S1G1
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 28
전체 시간: 1,140
