주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Brother PT-D200 LCD Screen Replacement
필요한 것
    1. Brother PT-D200 LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
      댓글 쓰기
    2. Brother PT-D200 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the six AAA batteries.
      댓글 쓰기
    1. Brother PT-D200 LCD Screen Replacement, Back of Device: 3 단계, 이미지 1개 중 1개
      • Use the Helping Hand 1/4" screwdriver to unscrew the six 3/16" corner screws.
      댓글 쓰기
    2. Brother PT-D200 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Close the back cover and then flip the device over and separate the top half from the bottom half as shown.
      • Be gentle when lifting the top of the device, there is a ribbon cable attaching the two halves together.
      댓글 쓰기
    1. Brother PT-D200 LCD Screen Replacement, Circuit Board Cables: 5 단계, 이미지 1개 중 1개
      • Gently pull out the ribbon cable from the circuit board.
      • The ribbon cable is very fragile.
      댓글 쓰기
    2. Brother PT-D200 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
      • Remove two-pin plastic connector from the circuit board.
      • Gently pull the two-pin connector from the circuit board to avoid damaging the board.
      댓글 쓰기
    1. Brother PT-D200 LCD Screen Replacement, Circuit Board: 7 단계, 이미지 2개 중 1개 Brother PT-D200 LCD Screen Replacement, Circuit Board: 7 단계, 이미지 2개 중 2개
      • Remove the two 3/16" screws from the circuit board using the Helping Hand 1/4" screwdriver.
      댓글 쓰기
    2. Brother PT-D200 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
      • Release the two black clips that hold the LCD cable ribbon in place. To release, pull the clips towards the ribbon.
      댓글 쓰기
    3. Brother PT-D200 LCD Screen Replacement: 9 단계, 이미지 1개 중 1개
      • Disconnect the LCD ribbon cable from the circuit board.
      댓글 쓰기
    1. Brother PT-D200 LCD Screen Replacement, Face Plate: 10 단계, 이미지 1개 중 1개
      • On the top portion of the device there are four grey clips locking the faceplate in place. The two top clips are circled in the image. The two others are located in the other corners of the device.
      댓글 쓰기
    2. Brother PT-D200 LCD Screen Replacement: 11 단계, 이미지 2개 중 1개 Brother PT-D200 LCD Screen Replacement: 11 단계, 이미지 2개 중 2개
      • Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off.
      댓글 쓰기
    1. Brother PT-D200 LCD Screen Replacement, Keyboard: 12 단계, 이미지 2개 중 1개 Brother PT-D200 LCD Screen Replacement, Keyboard: 12 단계, 이미지 2개 중 2개
      • Peel off the rubber keyboard of the device.
      댓글 쓰기
    1. Brother PT-D200 LCD Screen Replacement, LCD Screen: 13 단계, 이미지 2개 중 1개 Brother PT-D200 LCD Screen Replacement, LCD Screen: 13 단계, 이미지 2개 중 2개
      • Lift the LCD screen out of place.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Jeston Mitchell
회원 가입일: 01/24/14
308 평판
안내서 3개를 작성함
Cal Poly, Team 13-16, Regan Winter 2014 Cal Poly, Team 13-16, Regan Winter 2014 회원
CPSU-REGAN-W14S13G16
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 40
전체 시간: 2,544
