주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
C-Clamp Sternum Strap Replacement
  1. C-Clamp Sternum Strap Replacement, C-Clamp Sternum Strap Replacement: 1 단계, 이미지 2개 중 1개 C-Clamp Sternum Strap Replacement, C-Clamp Sternum Strap Replacement: 1 단계, 이미지 2개 중 2개
    • Locate the sternum strap that has come off the pack.
    • Replacements for this style of sternum strap are not currently available, so if part or all of the sternum strap is missing, reach out to Patagonia for alternative options.
    댓글 쓰기
  2. C-Clamp Sternum Strap Replacement: 2 단계, 이미지 3개 중 1개 C-Clamp Sternum Strap Replacement: 2 단계, 이미지 3개 중 2개 C-Clamp Sternum Strap Replacement: 2 단계, 이미지 3개 중 3개
    • The 'c-clamp' piece of the sternum strap fits over a plastic tube or ‘rail’ that is inside the backpack strap. At the bottom of this rail there is a fabric flap.
    • Pull back the fabric flap to expose where the rail ends. This is where the c-clamp was designed to be slid on and off.
    댓글 쓰기
    • At the exposed area at the base of the rail, slide the c-clamp back onto the rail.
    • Pull tightly on the fabric flap to expose the area.
    • Maneuver as if parallel parking a car. Start at an angle, slide partially onto the rail, and then straighten out.
    • This can be difficult to do, don’t be shy using some muscle!
    • Repeat the steps above on the other backpack strap.
    댓글 쓰기
  3. C-Clamp Sternum Strap Replacement: 4 단계, 이미지 2개 중 1개 C-Clamp Sternum Strap Replacement: 4 단계, 이미지 2개 중 2개
    • Slide the sternum strap to your desired position.
    • Hit the trails with your newly attached sternum strap!
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Zach Mueller
회원 가입일: 02/23/23
1,789 평판
안내서 9개를 작성함
Patagonia Patagonia 회원
Community
9 회원들
안내서 154개를 작성함
2가이드 댓글
This is helpful, except where do I find the replacement part! I contacted Patagonia and they no longer make it; they said to try a local sporting goods store or to send to Patagonia and they'll sew on a new daisy-chain version. My local REI does not have these parts either. Bummer!
Jornywar - 답글 공유
paul.butera - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 33
지난 30일: 143
전체 시간: 4,554
