주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
CASIO CDP-230R Button Panel Replacement
필요한 것
  1. CASIO CDP-230R Button Panel Replacement, Panels: 1 단계, 이미지 3개 중 1개 CASIO CDP-230R Button Panel Replacement, Panels: 1 단계, 이미지 3개 중 2개 CASIO CDP-230R Button Panel Replacement, Panels: 1 단계, 이미지 3개 중 3개
    • Flip the keyboard upside down, with the keys on a flat surface.
    • Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
    댓글 쓰기
  2. CASIO CDP-230R Button Panel Replacement: 2 단계, 이미지 3개 중 1개 CASIO CDP-230R Button Panel Replacement: 2 단계, 이미지 3개 중 2개 CASIO CDP-230R Button Panel Replacement: 2 단계, 이미지 3개 중 3개
    • Use two hands to grab the side panel from both sides.
    • Pull the panel apart from the device one side at a time.
    • There will be popping sounds when you remove this panel.
    • One side panel will not have an orange & white cable connected to it.
    댓글 쓰기
  3. CASIO CDP-230R Button Panel Replacement: 3 단계, 이미지 3개 중 1개 CASIO CDP-230R Button Panel Replacement: 3 단계, 이미지 3개 중 2개 CASIO CDP-230R Button Panel Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the three silver 10mm screws with a J1 screwdriver on the bottom half of the innermost side panel of the device.
    • One side panel will not have an orange & white cable running through.
    댓글 쓰기
  4. CASIO CDP-230R Button Panel Replacement: 4 단계, 이미지 3개 중 1개 CASIO CDP-230R Button Panel Replacement: 4 단계, 이미지 3개 중 2개 CASIO CDP-230R Button Panel Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the innermost side panel by pinching the top and bottom of the panel and pulling the panel off with both hands.
    • Repeat steps one through four to remove the other side panel of the keyboard.
    댓글 쓰기
  5. CASIO CDP-230R Button Panel Replacement: 5 단계, 이미지 3개 중 1개 CASIO CDP-230R Button Panel Replacement: 5 단계, 이미지 3개 중 2개 CASIO CDP-230R Button Panel Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the two black 30 mm J head screws with a J1 screwdriver to remove the long black bar.
    • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver and the two brackets from the back panel.
    • There will be two screws per bracket.
    댓글 쓰기
  6. CASIO CDP-230R Button Panel Replacement: 6 단계, 이미지 3개 중 1개 CASIO CDP-230R Button Panel Replacement: 6 단계, 이미지 3개 중 2개 CASIO CDP-230R Button Panel Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the eight silver 10mm x 1.5mm J head screws with a J1 screwdriver and the square tabs from the back panel.
    • Remove the eight silver 10mm J head screws with a J1 screwdriver underneath the square tabs.
    댓글 쓰기
  7. CASIO CDP-230R Button Panel Replacement: 7 단계, 이미지 3개 중 1개 CASIO CDP-230R Button Panel Replacement: 7 단계, 이미지 3개 중 2개 CASIO CDP-230R Button Panel Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the 36 silver 10mm J head screws with a J1 screwdriver from the back panel.
    댓글 쓰기
  8. CASIO CDP-230R Button Panel Replacement: 8 단계, 이미지 3개 중 1개 CASIO CDP-230R Button Panel Replacement: 8 단계, 이미지 3개 중 2개 CASIO CDP-230R Button Panel Replacement: 8 단계, 이미지 3개 중 3개
    • Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
    • Having a extra pair of hands will be useful.
    • Grab the center of the front panel with two hands and lift to remove panel.
    • Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
    댓글 쓰기
  9. CASIO CDP-230R Button Panel Replacement, Main Circuit Board: 9 단계, 이미지 2개 중 1개 CASIO CDP-230R Button Panel Replacement, Main Circuit Board: 9 단계, 이미지 2개 중 2개
    • The main circuit board is located on the green side of the button panel. The main circuit board is the smaller green board.
    • Grasp the white ribbon lined with foam and pull up to remove from the main circuit board.
    • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver.
    댓글 쓰기
  10. CASIO CDP-230R Button Panel Replacement: 10 단계, 이미지 1개 중 1개
    • Lift the main circuit board from the button panel.
    댓글 쓰기
  11. CASIO CDP-230R Button Panel Replacement: 11 단계, 이미지 3개 중 1개 CASIO CDP-230R Button Panel Replacement: 11 단계, 이미지 3개 중 2개 CASIO CDP-230R Button Panel Replacement: 11 단계, 이미지 3개 중 3개
    • Grip the white plastic end of the orange and white cables that is attached to the right side of the main circuit board and pull to the right.
    • Repeat for the orange and white cables attached to the left side of the main circuit board and pull up.
    댓글 쓰기
  12. CASIO CDP-230R Button Panel Replacement, Button Panel: 12 단계, 이미지 2개 중 1개 CASIO CDP-230R Button Panel Replacement, Button Panel: 12 단계, 이미지 2개 중 2개
    • Remove the 11 7.5mm J head screws from the yellow button panel by using a J1 screwdriver.
    댓글 쓰기
  13. CASIO CDP-230R Button Panel Replacement: 13 단계, 이미지 2개 중 1개 CASIO CDP-230R Button Panel Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the 19 9mm J head screws from the green button panel by using a J1 screwdriver.
    댓글 쓰기
  14. CASIO CDP-230R Button Panel Replacement: 14 단계, 이미지 2개 중 1개 CASIO CDP-230R Button Panel Replacement: 14 단계, 이미지 2개 중 2개
    • Lift the yellow side of the button panel first, then lift green side to remove the entire button panel together.
    • The yellow button panel will make a pop sound when removing it.
    • The volume knob will come off with the yellow circuit board. To place the knob back, snap it back into the socket on the outside of the front panel.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Areli Reyes
회원 가입일: 10/01/17
545 평판
안내서 4개를 작성함
Cal Poly, Team S4-G2, Livingston Fall 2017 Cal Poly, Team S4-G2, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S4G2
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 28
전체 시간: 2,276
