주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
CASIO CDP-230R Pitch Bend Replacement
필요한 것
    1. CASIO CDP-230R Pitch Bend Replacement, Panels: 1 단계, 이미지 3개 중 1개 CASIO CDP-230R Pitch Bend Replacement, Panels: 1 단계, 이미지 3개 중 2개 CASIO CDP-230R Pitch Bend Replacement, Panels: 1 단계, 이미지 3개 중 3개
      • Flip the keyboard upside down, with the keys on a flat surface.
      • Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
      댓글 쓰기
    2. CASIO CDP-230R Pitch Bend Replacement: 2 단계, 이미지 3개 중 1개 CASIO CDP-230R Pitch Bend Replacement: 2 단계, 이미지 3개 중 2개 CASIO CDP-230R Pitch Bend Replacement: 2 단계, 이미지 3개 중 3개
      • Use two hands to grab the side panel from both sides.
      • Pull the panel apart from the device one side at a time.
      • There will be popping sounds when you remove this panel.
      • One side panel will not have an orange & white cable connected to it.
      댓글 쓰기
    3. CASIO CDP-230R Pitch Bend Replacement: 3 단계, 이미지 3개 중 1개 CASIO CDP-230R Pitch Bend Replacement: 3 단계, 이미지 3개 중 2개 CASIO CDP-230R Pitch Bend Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the three silver 10mm screws with a J1 screwdriver on the bottom half of the innermost side panel of the device.
      • One side panel will not have an orange & white cable running through.
      댓글 쓰기
    4. CASIO CDP-230R Pitch Bend Replacement: 4 단계, 이미지 3개 중 1개 CASIO CDP-230R Pitch Bend Replacement: 4 단계, 이미지 3개 중 2개 CASIO CDP-230R Pitch Bend Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the innermost side panel by pinching the top and bottom of the panel and pulling the panel off with both hands.
      • Repeat steps one through four to remove the other side panel of the keyboard.
      댓글 쓰기
    5. CASIO CDP-230R Pitch Bend Replacement: 5 단계, 이미지 3개 중 1개 CASIO CDP-230R Pitch Bend Replacement: 5 단계, 이미지 3개 중 2개 CASIO CDP-230R Pitch Bend Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the two black 30 mm J head screws with a J1 screwdriver to remove the long black bar.
      • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver and the two brackets from the back panel.
      • There will be two screws per bracket.
      댓글 쓰기
    6. CASIO CDP-230R Pitch Bend Replacement: 6 단계, 이미지 3개 중 1개 CASIO CDP-230R Pitch Bend Replacement: 6 단계, 이미지 3개 중 2개 CASIO CDP-230R Pitch Bend Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the eight silver 10mm x 1.5mm J head screws with a J1 screwdriver and the square tabs from the back panel.
      • Remove the eight silver 10mm J head screws with a J1 screwdriver underneath the square tabs.
      댓글 쓰기
    7. CASIO CDP-230R Pitch Bend Replacement: 7 단계, 이미지 3개 중 1개 CASIO CDP-230R Pitch Bend Replacement: 7 단계, 이미지 3개 중 2개 CASIO CDP-230R Pitch Bend Replacement: 7 단계, 이미지 3개 중 3개
      • Remove the 36 silver 10mm J head screws with a J1 screwdriver from the back panel.
      댓글 쓰기
    8. CASIO CDP-230R Pitch Bend Replacement: 8 단계, 이미지 3개 중 1개 CASIO CDP-230R Pitch Bend Replacement: 8 단계, 이미지 3개 중 2개 CASIO CDP-230R Pitch Bend Replacement: 8 단계, 이미지 3개 중 3개
      • Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
      • Having a extra pair of hands will be useful.
      • Grab the center of the front panel with two hands and lift to remove panel.
      • Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
      댓글 쓰기
    1. CASIO CDP-230R Pitch Bend Replacement, Pitch Bend: 9 단계, 이미지 3개 중 1개 CASIO CDP-230R Pitch Bend Replacement, Pitch Bend: 9 단계, 이미지 3개 중 2개 CASIO CDP-230R Pitch Bend Replacement, Pitch Bend: 9 단계, 이미지 3개 중 3개
      • Remove the two 8mm x 1.5mm J screws from the inside of the side panel by using a J1 head screwdriver.
      • Slide the pitch bend out of the side panel.
      댓글 쓰기
    2. CASIO CDP-230R Pitch Bend Replacement: 10 단계, 이미지 2개 중 1개 CASIO CDP-230R Pitch Bend Replacement: 10 단계, 이미지 2개 중 2개
      • Follow the white and orange cable to the white end that is attached to the button panel
      • Pinch the white end and pull the cord out
      댓글 쓰기
    3. CASIO CDP-230R Pitch Bend Replacement: 11 단계, 이미지 1개 중 1개
      • Run the white and orange cable through the innermost side panel and pull out
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Areli Reyes
회원 가입일: 10/01/17
545 평판
안내서 4개를 작성함
Cal Poly, Team S4-G2, Livingston Fall 2017 Cal Poly, Team S4-G2, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S4G2
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 22
전체 시간: 890
