주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
CASIO CDP-230R Speaker Replacement
필요한 것
  1. CASIO CDP-230R Speaker Replacement, Panels: 1 단계, 이미지 3개 중 1개 CASIO CDP-230R Speaker Replacement, Panels: 1 단계, 이미지 3개 중 2개 CASIO CDP-230R Speaker Replacement, Panels: 1 단계, 이미지 3개 중 3개
    • Flip the keyboard upside down, with the keys on a flat surface.
    • Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
    댓글 쓰기
  2. CASIO CDP-230R Speaker Replacement: 2 단계, 이미지 3개 중 1개 CASIO CDP-230R Speaker Replacement: 2 단계, 이미지 3개 중 2개 CASIO CDP-230R Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Use two hands to grab the side panel from both sides.
    • Pull the panel apart from the device one side at a time.
    • There will be popping sounds when you remove this panel.
    • One side panel will not have an orange & white cable connected to it.
    댓글 쓰기
  3. CASIO CDP-230R Speaker Replacement: 3 단계, 이미지 3개 중 1개 CASIO CDP-230R Speaker Replacement: 3 단계, 이미지 3개 중 2개 CASIO CDP-230R Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the three silver 10mm screws with a J1 screwdriver on the bottom half of the innermost side panel of the device.
    • One side panel will not have an orange & white cable running through.
    댓글 쓰기
  4. CASIO CDP-230R Speaker Replacement: 4 단계, 이미지 3개 중 1개 CASIO CDP-230R Speaker Replacement: 4 단계, 이미지 3개 중 2개 CASIO CDP-230R Speaker Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the innermost side panel by pinching the top and bottom of the panel and pulling the panel off with both hands.
    • Repeat steps one through four to remove the other side panel of the keyboard.
    댓글 쓰기
  5. CASIO CDP-230R Speaker Replacement: 5 단계, 이미지 3개 중 1개 CASIO CDP-230R Speaker Replacement: 5 단계, 이미지 3개 중 2개 CASIO CDP-230R Speaker Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the two black 30 mm J head screws with a J1 screwdriver to remove the long black bar.
    • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver and the two brackets from the back panel.
    • There will be two screws per bracket.
    댓글 쓰기
  6. CASIO CDP-230R Speaker Replacement: 6 단계, 이미지 3개 중 1개 CASIO CDP-230R Speaker Replacement: 6 단계, 이미지 3개 중 2개 CASIO CDP-230R Speaker Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the eight silver 10mm x 1.5mm J head screws with a J1 screwdriver and the square tabs from the back panel.
    • Remove the eight silver 10mm J head screws with a J1 screwdriver underneath the square tabs.
    댓글 쓰기
  7. CASIO CDP-230R Speaker Replacement: 7 단계, 이미지 3개 중 1개 CASIO CDP-230R Speaker Replacement: 7 단계, 이미지 3개 중 2개 CASIO CDP-230R Speaker Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the 36 silver 10mm J head screws with a J1 screwdriver from the back panel.
    댓글 쓰기
  8. CASIO CDP-230R Speaker Replacement: 8 단계, 이미지 3개 중 1개 CASIO CDP-230R Speaker Replacement: 8 단계, 이미지 3개 중 2개 CASIO CDP-230R Speaker Replacement: 8 단계, 이미지 3개 중 3개
    • Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
    • Having a extra pair of hands will be useful.
    • Grab the center of the front panel with two hands and lift to remove panel.
    • Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
    댓글 쓰기
  9. CASIO CDP-230R Speaker Replacement, Speaker: 9 단계, 이미지 1개 중 1개
    • Lay the speaker flat on the table and remove the four black 10mm J head screws with a J1 screwdriver.
    • You may want to use a screwdriver with a bigger handle for a better grip to remove these screws.
    댓글 쓰기
  10. CASIO CDP-230R Speaker Replacement: 10 단계, 이미지 2개 중 1개 CASIO CDP-230R Speaker Replacement: 10 단계, 이미지 2개 중 2개
    • Grasp the speaker from the center and lift the speaker out of the panel.
    댓글 쓰기
  11. CASIO CDP-230R Speaker Replacement: 11 단계, 이미지 2개 중 1개 CASIO CDP-230R Speaker Replacement: 11 단계, 이미지 2개 중 2개
    • Follow the cable from the speaker to the button panel.
    • Pull the speaker cable out of the button panel with a slight wiggle.
    • Repeat steps nine through eleven to remove the other speaker.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Irene Luong
회원 가입일: 10/02/17
314 평판
안내서 1개를 작성함
Cal Poly, Team S4-G2, Livingston Fall 2017 Cal Poly, Team S4-G2, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S4G2
4 회원들
안내서 6개를 작성함
1가이드 댓글
What is the part number for the CDP-230r speaker replacement? I cannot find them online or through Casio. Thanks.
Oli Morgan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 45
전체 시간: 2,287
