주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon A35F Battery Replacement
필요한 것
    1. Canon A35F Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Flip the Canon A35F on its top so that the bottom of the camera is facing up.
      • Spot the two windows on the bottom of the camera (each window has the word "OPEN" written, and an arrow, both pointing the same direction).
      • Use your fingernail (or a iFixit opening tool), and push in the direction of the arrow to open the left compartment.
      댓글 쓰기
    2. Canon A35F Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Wipe the PX-625 mercury battery with a clean cloth, so that there are no unnecessary fingerprints on the battery.
      • Place the mercury battery in the slot with the yellow ribbon.
      • Make sure to place it in the right side! If it is facing the wrong direction, the shutter will be locked and the meter needle will not move to the battery check zone.
      • Make sure not to leave fingerprints on the battery. It may cause corrosion to the camera's electric contact.
      댓글 쓰기
    3. Canon A35F Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Shut the left window close.
      댓글 쓰기
    4. Canon A35F Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Use your fingernail (or a iFixit opening tool), and push in the direction of the arrow to open the right compartment.
      댓글 쓰기
    5. Canon A35F Battery Replacement: 5 단계, 이미지 1개 중 1개
      • Insert the size AA battery, for the flash, into the compartment (make sure to insert the battery in the right direction).
      댓글 쓰기
    6. Canon A35F Battery Replacement: 6 단계, 이미지 1개 중 1개
      • Shut the right window close.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 100
전체 시간: 6,428
