주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon CanoScan N670U Sensor Bar Replacement
필요한 것
    1. Canon CanoScan N670U Sensor Bar Replacement, Canon CanoScan N670U Disassembly: 1 단계, 이미지 1개 중 1개
      • Open up your Canon CanoScan N670U to an upright position.
      댓글 쓰기
    2. Canon CanoScan N670U Sensor Bar Replacement: 2 단계, 이미지 1개 중 1개
      • Turn your device so that you're facing the long side of the Canon CanoScan N670U.
      • Locate the small crevice between the plastic components of the scanner bed and the scanner base.
      댓글 쓰기
    3. Canon CanoScan N670U Sensor Bar Replacement: 3 단계, 이미지 1개 중 1개
      • Carefully insert a metal spudger tool in the crevice and slowly cut through the adhesive between the plastic components.
      • You may cut small bits of the plastic as you're slicing the adhesive. Do not forcefully bend the plastic strip as you're cutting or it will snap.
      댓글 쓰기
    4. Canon CanoScan N670U Sensor Bar Replacement: 4 단계, 이미지 1개 중 1개
      • Once the adhesive strip is sliced through, the plastic bar that is attached should release. Set aside the plastic bar.
      댓글 쓰기
    5. Canon CanoScan N670U Sensor Bar Replacement: 5 단계, 이미지 1개 중 1개
      • Repeat steps 2-4 for the other side of the scanner.
      댓글 쓰기
    6. Canon CanoScan N670U Sensor Bar Replacement: 6 단계, 이미지 1개 중 1개
      • Use your hands or a metal spudger tool to push the plastic bar at the bottom of the glass scanner bed forward until you can't push it any farther.
      댓글 쓰기
    7. Canon CanoScan N670U Sensor Bar Replacement: 7 단계, 이미지 1개 중 1개
      • Insert the metal spudger tool underneath the glass scanner bed. The front of the scanner bed should be resting on top of the tool.
      댓글 쓰기
    8. Canon CanoScan N670U Sensor Bar Replacement: 8 단계, 이미지 1개 중 1개
      • Slowly pull the glass scanner bed towards you and set the piece aside.
      댓글 쓰기
    1. Canon CanoScan N670U Sensor Bar Replacement, Sensor Bar: 9 단계, 이미지 1개 중 1개
      • This is the sensor bar that you will replace.
      댓글 쓰기
    2. Canon CanoScan N670U Sensor Bar Replacement: 10 단계, 이미지 2개 중 1개 Canon CanoScan N670U Sensor Bar Replacement: 10 단계, 이미지 2개 중 2개
      • Locate the small plug where the white strip of cable is connected to.
      • Unfurl the cable strip if it's tucked in.
      댓글 쓰기
    3. Canon CanoScan N670U Sensor Bar Replacement: 11 단계, 이미지 3개 중 1개 Canon CanoScan N670U Sensor Bar Replacement: 11 단계, 이미지 3개 중 2개 Canon CanoScan N670U Sensor Bar Replacement: 11 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Gently use tweezers or your fingers to rock the cable back and forth to disconnect the it.
      • Do not apply too much pressure or you may damage some delicate components.
      댓글 쓰기
    4. Canon CanoScan N670U Sensor Bar Replacement: 12 단계, 이미지 1개 중 1개
      • Locate the small metal spring behind the front buttons of the Canon CanoScan N670U.
      댓글 쓰기
    5. Canon CanoScan N670U Sensor Bar Replacement: 13 단계, 이미지 2개 중 1개 Canon CanoScan N670U Sensor Bar Replacement: 13 단계, 이미지 2개 중 2개
      • Use tweezers to gently remove the metal spring from the plastic hook.
      • Due to the tension of the spring, it can be difficult to pull the metal end. You may attempt to use your hands to pull the spring itself if necessary.
      • Take caution to not bend the metal.
      댓글 쓰기
    6. Canon CanoScan N670U Sensor Bar Replacement: 14 단계, 이미지 2개 중 1개 Canon CanoScan N670U Sensor Bar Replacement: 14 단계, 이미지 2개 중 2개
      • Flip the sensor bar over and unwind the belt from the gear system.
      댓글 쓰기
    7. Canon CanoScan N670U Sensor Bar Replacement: 15 단계, 이미지 1개 중 1개
      • Remove the sensor bar from the scanner and replace it with the new one.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Stephen Bui
회원 가입일: 09/19/15
558 평판
안내서 4개를 작성함
USF Sarasota-Manatee, Team 1-1, Stewart Fall 2015 USF Sarasota-Manatee, Team 1-1, Stewart Fall 2015 회원
USFSM-STEWART-F15S1G1
5 회원들
안내서 88개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 44
전체 시간: 1,270
