주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon EOS 40D LCD Replacement
필요한 것
    1. Canon EOS 40D LCD Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Locate the battery compartment cover on the bottom of the camera below the shutter button.
      댓글 쓰기
    2. Canon EOS 40D LCD Replacement: 2 단계, 이미지 1개 중 1개
      • Find the marked arrow on the battery compartment cover labeled "BATT. OPEN". Slide the lever following the arrow's direction and lift at the same time to release the latch.
      댓글 쓰기
    3. Canon EOS 40D LCD Replacement: 3 단계, 이미지 1개 중 1개
      • Release the lever and allow the battery compartment cover to completely open.
      • Remove the battery.
      댓글 쓰기
    1. Canon EOS 40D LCD Replacement, LCD: 4 단계, 이미지 1개 중 1개
      • Remove the rubber eyepiece by sliding it upwards.
      댓글 쓰기
    2. Canon EOS 40D LCD Replacement: 5 단계, 이미지 3개 중 1개 Canon EOS 40D LCD Replacement: 5 단계, 이미지 3개 중 2개 Canon EOS 40D LCD Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the three 5.0 mm Phillips #000 screws.
      • Remove the two 3.0 mm Phillips #000 screws on the bottom of the camera.
      댓글 쓰기
    3. Canon EOS 40D LCD Replacement: 6 단계, 이미지 3개 중 1개 Canon EOS 40D LCD Replacement: 6 단계, 이미지 3개 중 2개 Canon EOS 40D LCD Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the side cover using a plastic opening tool or your hands.
      • Use a plastic opening tool to gently start prying the rear case up from the rest of the camera.
      • Use the tip of a spudger to disconnect the ZIF connector on the left side of the camera. The ribbon cable on this device was torn in the process of removing the back case, so there are no photos showing this step.
      • Disconnect the ribbon cable securing the rear case to the motherboard.
      • Separate the rear case from the camera.
      댓글 쓰기
    4. Canon EOS 40D LCD Replacement: 7 단계, 이미지 2개 중 1개 Canon EOS 40D LCD Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the five 5.0 mm Phillips #000 screws securing the LCD to the rear case.
      • Lift the LCD free of the rear case.
      댓글 쓰기
    5. Canon EOS 40D LCD Replacement: 8 단계, 이미지 3개 중 1개 Canon EOS 40D LCD Replacement: 8 단계, 이미지 3개 중 2개 Canon EOS 40D LCD Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the yellow tape covering the LCD ZIF connector.
      • Use a plastic opening tool to lift up the black retaining flap.
      • Pull the LCD ribbon cable out of the connector.
      댓글 쓰기
    6. Canon EOS 40D LCD Replacement: 9 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use a pair of tweezers to disconnect the cable connector.
      • The LCD frame should now come free of the LCD panel.
      댓글 쓰기
    7. Canon EOS 40D LCD Replacement: 10 단계, 이미지 1개 중 1개
      • LCD panel remains.
      • It's a good idea to use a soft cloth to wipe the LCD screen and rear cover before reassembly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Diarra Thomas
회원 가입일: 09/03/15
172 평판
안내서 1개를 작성함
USF Tampa, Team 12-3, Blackwell Fall 2015 USF Tampa, Team 12-3, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G3
4 회원들
안내서 16개를 작성함
2가이드 댓글
For the life of me, I cannot remove the two screws on either side of the view-finder!
tomaska - 답글 공유
On the unit are brought on eBay for parts all the screws came out fine.But on the camera I was repairing I had to remove the left hand viewfinder screw by takings its head off with a Dremel rotary tool!!!
Robin Taylor - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 71
전체 시간: 5,726
