주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon EOS 5D Mark II Clock Battery Replacement
필요한 것
    1. Canon EOS 5D Mark II Clock Battery Replacement, Clock Battery: 1 단계, 이미지 1개 중 1개
      • Lift the rubber flap covering the input/output jacks.
      댓글 쓰기
    2. Canon EOS 5D Mark II Clock Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Using a Phillips #000, remove the single 3.4 mm screw.
      댓글 쓰기
    3. Canon EOS 5D Mark II Clock Battery Replacement: 3 단계, 이미지 1개 중 1개
      • This step will permanently erase all user settings.
      • The memory battery can now be easily slid out of place.
      • If you are following this guide in an effort to perform a hard reset, you should now press the shutter button multiple times in order to drain any left over power, then replace the batteries and power the device back on. You have just performed a hard reset!
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 17명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Mike Seed
회원 가입일: 09/22/14
3,166 평판
안내서 8개를 작성함
USF Tampa, Team 1-6, Hickman Fall 2014 USF Tampa, Team 1-6, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G6
3 회원들
안내서 17개를 작성함
4가이드 댓글
This Battery for Clock only? or CMos and Personal setting to?
there has to be something to retain all these settings once the main battery pack goes dead and or is removed from the camera?
My User 1 Pictures styles wont Save? it'll save but once i turn off My Canon Eos 5D Mark II and then back on again, my Color /Contrast/Sharpness are all Dead Center/= back to Default AGAIN? :/
Any Help here?
THANK YOU,
Greg - 답글 공유
I did not write the original post, but I believe once you remove this battery ALL custom changes and time will be gone. You will have to re-create them. Besides the rechargeable battery, the only one keeping track of some settings is this one.
CL
Carlos Lijeron - 답글 공유
Will doing this reset the shutter count in the camera? Like when you go to an external program to see how many shutter actuations there have been over the lifetime of the camera, will that number be erased?
Tom Fewchuk - 답글 공유
No, because some faulty behavior i removed my clock battery from my 5D MK2, but the shutter count is still the same, it would be to easy to hack a camera to be sold on a good price. :)
Vass János Szilárd - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 21
지난 30일: 100
전체 시간: 29,244
