주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon EOS 5D Mark II Front Panel Replacement
필요한 것
  1. Canon EOS 5D Mark II Front Panel Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Peel back the rubber cover above the in/out ports to reveal two screw heads.
    댓글 쓰기
  2. Canon EOS 5D Mark II Front Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Remove both 5.4 mm screws using a Phillips #0.
    댓글 쓰기
  3. Canon EOS 5D Mark II Front Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the in/out port plastic covering from the bottom where the backup battery used to be.
    댓글 쓰기
  4. Canon EOS 5D Mark II Front Panel Replacement: 4 단계, 이미지 1개 중 1개
    • Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
    댓글 쓰기
  5. Canon EOS 5D Mark II Front Panel Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the three 4.8 mm screws on the bottom of the back plate using a Phillips #0.
    댓글 쓰기
  6. Canon EOS 5D Mark II Front Panel Replacement: 6 단계, 이미지 1개 중 1개
    • Peel back the rubber covering next to the menu dial to access the screw.
    • Remove the single 3.4 mm screw using a Phillips #0.
    댓글 쓰기
  7. Canon EOS 5D Mark II Front Panel Replacement: 7 단계, 이미지 1개 중 1개
    • The back panel can now fall off easily by turning the device upside down. Be sure to catch it so the data ribbons do not tear or tug.
    댓글 쓰기
  8. Canon EOS 5D Mark II Front Panel Replacement: 8 단계, 이미지 1개 중 1개
    • Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
    • The back panel is now free from the rest of the device.
    댓글 쓰기
  9. Canon EOS 5D Mark II Front Panel Replacement, Front Panel: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, pull out the wire attaching the front panel to the motherboard.
    댓글 쓰기
  10. Canon EOS 5D Mark II Front Panel Replacement: 10 단계, 이미지 1개 중 1개
    • Peel off the rubber cover on the front panel in order to access the screws underneath.
    댓글 쓰기
  11. Canon EOS 5D Mark II Front Panel Replacement: 11 단계, 이미지 1개 중 1개
    • Remove each of the 4.9 mm three screws using a Phillips #0.
    댓글 쓰기
  12. Canon EOS 5D Mark II Front Panel Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the two 4.8 mm screws above where the lens would be using a Phillips #0.
    댓글 쓰기
  13. Canon EOS 5D Mark II Front Panel Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the single screw underneath where the lens would be using a Phillips #0.
    댓글 쓰기
  14. Canon EOS 5D Mark II Front Panel Replacement: 14 단계, 이미지 3개 중 1개 Canon EOS 5D Mark II Front Panel Replacement: 14 단계, 이미지 3개 중 2개 Canon EOS 5D Mark II Front Panel Replacement: 14 단계, 이미지 3개 중 3개
    • Remove the four 3.0 mm screws next to the memory card reader using a Phillips #0.
    댓글 쓰기
  15. Canon EOS 5D Mark II Front Panel Replacement: 15 단계, 이미지 2개 중 1개 Canon EOS 5D Mark II Front Panel Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the front panel by lifting upwards from the right side where the in/out ports used to be.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 14명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Mike Seed
회원 가입일: 09/22/14
3,166 평판
안내서 8개를 작성함
USF Tampa, Team 1-6, Hickman Fall 2014 USF Tampa, Team 1-6, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G6
3 회원들
안내서 17개를 작성함
1가이드 댓글
Good write-up. I just replaced my casing using these instructions.
sebastien - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 20
지난 30일: 109
전체 시간: 12,615
