주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon EOS 5D Mark II LCD Replacement
필요한 것
    1. Canon EOS 5D Mark II LCD Replacement, Clock Battery: 1 단계, 이미지 1개 중 1개
      • Lift the rubber flap covering the input/output jacks.
      댓글 쓰기
    2. Canon EOS 5D Mark II LCD Replacement: 2 단계, 이미지 1개 중 1개
      • Using a Phillips #000, remove the single 3.4 mm screw.
      댓글 쓰기
    3. Canon EOS 5D Mark II LCD Replacement: 3 단계, 이미지 1개 중 1개
      • This step will permanently erase all user settings.
      • The memory battery can now be easily slid out of place.
      • If you are following this guide in an effort to perform a hard reset, you should now press the shutter button multiple times in order to drain any left over power, then replace the batteries and power the device back on. You have just performed a hard reset!
      댓글 쓰기
    1. Canon EOS 5D Mark II LCD Replacement, Back Panel: 4 단계, 이미지 1개 중 1개
      • Peel back the rubber cover above the in/out ports to reveal two screw heads.
      댓글 쓰기
    2. Canon EOS 5D Mark II LCD Replacement: 5 단계, 이미지 1개 중 1개
      • Remove both 5.4 mm screws using a Phillips #0.
      댓글 쓰기
    3. Canon EOS 5D Mark II LCD Replacement: 6 단계, 이미지 1개 중 1개
      • Lift the in/out port plastic covering from the bottom where the backup battery used to be.
      댓글 쓰기
    4. Canon EOS 5D Mark II LCD Replacement: 7 단계, 이미지 1개 중 1개
      • Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
      댓글 쓰기
    5. Canon EOS 5D Mark II LCD Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the three 4.8 mm screws on the bottom of the back plate using a Phillips #0.
      댓글 쓰기
    6. Canon EOS 5D Mark II LCD Replacement: 9 단계, 이미지 1개 중 1개
      • Peel back the rubber covering next to the menu dial to access the screw.
      • Remove the single 3.4 mm screw using a Phillips #0.
      댓글 쓰기
    7. Canon EOS 5D Mark II LCD Replacement: 10 단계, 이미지 1개 중 1개
      • The back panel can now fall off easily by turning the device upside down. Be sure to catch it so the data ribbons do not tear or tug.
      댓글 쓰기
    8. Canon EOS 5D Mark II LCD Replacement: 11 단계, 이미지 1개 중 1개
      • Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
      • The back panel is now free from the rest of the device.
      댓글 쓰기
    1. Canon EOS 5D Mark II LCD Replacement, LCD: 12 단계, 이미지 3개 중 1개 Canon EOS 5D Mark II LCD Replacement, LCD: 12 단계, 이미지 3개 중 2개 Canon EOS 5D Mark II LCD Replacement, LCD: 12 단계, 이미지 3개 중 3개
      • Remove each of the 3.4 mm screws holding in the LCD using a Phillips #0.
      댓글 쓰기
    2. Canon EOS 5D Mark II LCD Replacement: 13 단계, 이미지 1개 중 1개
      • Grip the wire attaching the speaker to the data ribbon cable and pull it out.
      • The LCD is now free from the back panel.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Mike Seed
회원 가입일: 09/22/14
3,166 평판
안내서 8개를 작성함
USF Tampa, Team 1-6, Hickman Fall 2014 USF Tampa, Team 1-6, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G6
3 회원들
안내서 17개를 작성함
5가이드 댓글
Step 8: Missing indication to remove also the third screw on the left, just next to the connector cover
Techtronics - 답글 공유
where can get the lcd screen? thanks for the guide!!
Birger Heimdal - 답글 공유
Big thank you! This walkthrough really helped ;) fortunatelly only one of the connecting cables slided out of the socket that caused the lcd dead. Cam is back in business in 15 minutes ;)
hotpixelstudio - 답글 공유
Step 2 missing indication that 2 other screws are removed near lower input/output jacks just above
memory battery location.
Pete - 답글 공유
Also....the last step should mention unclipping the ribbon cables in the same manner as before from the small circuit board that resides on the rear of the LCD, and the LCD has a metal frame that will need to be removed and installed on the replacement LCD before installing it. It is held in place via strong double sided tape. A little heat may need to be applied to separate it.
Pete - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 21
지난 30일: 70
전체 시간: 12,451
