주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon EOS 6D Rear Body Panel Replacement
필요한 것
  1. Canon EOS 6D Rear Body Panel Replacement, Rear Body Panel: 1 단계, 이미지 1개 중 1개
    • Remove the viewfinder cover by pinching the sides and sliding it upward.
    댓글 쓰기
  2. Canon EOS 6D Rear Body Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Open the battery door on the bottom of the camera.
    • Use your thumb to slide the small black tab on the inside of the battery door up and pull the door off the camera.
    댓글 쓰기
  3. Canon EOS 6D Rear Body Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Slide your fingernail or the flat end of the spudger underneath the rubber covering and gently peel it off all sides of the camera.
    댓글 쓰기
  4. Canon EOS 6D Rear Body Panel Replacement: 4 단계, 이미지 1개 중 1개
    • Open the covers to the HDMI/AV/MIC ports on the side of the camera by gently pulling outward on the bottom of the covers.
    • Rotate the covers to the side so that you can see the connection ports inside.
    • Remove the following screws:
    • Two silver 5mm Phillips #00
    • One black 6mm Phillips #00
    댓글 쓰기
  5. Canon EOS 6D Rear Body Panel Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the cover to the HDMI/AV/MIC ports by gently lifting the tab on the bottom edge of the camera.
    댓글 쓰기
  6. Canon EOS 6D Rear Body Panel Replacement: 6 단계, 이미지 1개 중 1개
    • Rotate your camera so the bottom side is facing you.
    • One 6mm Phillips #00
    • Two 3mm Phillips #00
    댓글 쓰기
  7. Canon EOS 6D Rear Body Panel Replacement: 7 단계, 이미지 1개 중 1개
    • Rotate your camera so the back is facing you.
    • Three silver 5mm Phillips #00
    • Two black 6mm Phillips #00
    • One black 4mm Phillips #00
    댓글 쓰기
  8. Canon EOS 6D Rear Body Panel Replacement: 8 단계, 이미지 2개 중 1개 Canon EOS 6D Rear Body Panel Replacement: 8 단계, 이미지 2개 중 2개
    • A black ribbon wire connects the rear panel to the inside of the camera. Breaking this wire would make your rear screen and buttons non-functional.
    • Carefully use your fingers to tilt the back panel downward to about a 90 degree angle.
    • Use the flat end of the spudger to gently pry off the ribbon wire from the inside of the camera.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 12명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Justin Thomas
회원 가입일: 04/22/14
2,233 평판
안내서 6개를 작성함
Cal Poly, Team 11-48, Amido Spring 2014 Cal Poly, Team 11-48, Amido Spring 2014 회원
CPSU-AMIDO-S14S11G48
4 회원들
안내서 20개를 작성함
2가이드 댓글
Thanks alot, very helpful
busulwa paddy - 답글 공유
Thanks alot, very helpful fixed an issue
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 55
전체 시간: 10,974
