주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon EOS Rebel G LCD Screen Replacement
필요한 것
  1. Canon EOS Rebel G LCD Screen Replacement, Front Panel: 1 단계, 이미지 1개 중 1개
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
    댓글 쓰기
  2. Canon EOS Rebel G LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 Canon EOS Rebel G LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Using your finger, peel back the textured grip so the components are separated.
    댓글 쓰기
  3. Canon EOS Rebel G LCD Screen Replacement: 3 단계, 이미지 3개 중 1개 Canon EOS Rebel G LCD Screen Replacement: 3 단계, 이미지 3개 중 2개 Canon EOS Rebel G LCD Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
    댓글 쓰기
  4. Canon EOS Rebel G LCD Screen Replacement, Top Panel: 4 단계, 이미지 1개 중 1개
    • Turn Camera over.
    • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
    댓글 쓰기
  5. Canon EOS Rebel G LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
    댓글 쓰기
  6. Canon EOS Rebel G LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Lay the camera on its back.
    • Unsolder the flash connection from the motherboard as noted by the blue circle.
    댓글 쓰기
  7. Canon EOS Rebel G LCD Screen Replacement: 7 단계, 이미지 3개 중 1개 Canon EOS Rebel G LCD Screen Replacement: 7 단계, 이미지 3개 중 2개 Canon EOS Rebel G LCD Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
    댓글 쓰기
  8. Canon EOS Rebel G LCD Screen Replacement, LCD Screen: 8 단계, 이미지 2개 중 1개 Canon EOS Rebel G LCD Screen Replacement, LCD Screen: 8 단계, 이미지 2개 중 2개
    • Pry off the small metal brace holding the LCD screen. (Push forward and slide toward the center)
    댓글 쓰기
  9. Canon EOS Rebel G LCD Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Lift out the LCD screen.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Zach
회원 가입일: 04/04/12
46 평판
안내서 8개를 작성함
Cal Poly, Team 14-9, Forte Spring 2012 Cal Poly, Team 14-9, Forte Spring 2012 회원
CPSU-FORTE-S12S14G9
5 회원들
안내서 36개를 작성함
2가이드 댓글
Great guide thanks! I found my lcd screen was partially working, the top part of the display was showing incomplete numbers...Cleaning the lcd contacts and reassembling it fixed the issue! No need to replace the screen in my case!
Michelangelo - 답글 공유
What Kind of glue is suggested to replace the textured grip?
Mark Garcia - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 27
전체 시간: 2,019
