주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon EOS Rebel T5 LCD Screen Replacement
필요한 것
    1. Canon EOS Rebel T5 LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Lay the camera on its back so that the card/battery door is facing you.
      • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
      댓글 쓰기
    2. Canon EOS Rebel T5 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Lift the now free card/battery door to reveal the battery compartment.
      • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
      댓글 쓰기
    1. Canon EOS Rebel T5 LCD Screen Replacement, Back Cover: 3 단계, 이미지 1개 중 1개
      • Turn the camera so that the back is facing to your right.
      • Remove the 5mm JIS #000 screw above the rubber USB port cover.
      댓글 쓰기
    2. Canon EOS Rebel T5 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the rubber piece.
      • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
      • It is held in place by a notched tether, but can be easily manipulated to slide out.
      댓글 쓰기
    3. Canon EOS Rebel T5 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Turn your camera so that the bottom is facing you.
      • Remove the four 5mm JIS #000 screws.
      댓글 쓰기
    4. Canon EOS Rebel T5 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
      • Now turn the camera so that the front is facing towards your right.
      • Remove the two remaining 5mm JIS #000 screws.
      댓글 쓰기
    5. Canon EOS Rebel T5 LCD Screen Replacement: 7 단계, 이미지 3개 중 1개 Canon EOS Rebel T5 LCD Screen Replacement: 7 단계, 이미지 3개 중 2개 Canon EOS Rebel T5 LCD Screen Replacement: 7 단계, 이미지 3개 중 3개
      • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
      • Gently pry the back panel from the main body of the camera.
      • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
      • This back panel contains various control components of the camera as well as the LCD screen.
      댓글 쓰기
    1. Canon EOS Rebel T5 LCD Screen Replacement, LCD Screen: 8 단계, 이미지 2개 중 1개 Canon EOS Rebel T5 LCD Screen Replacement, LCD Screen: 8 단계, 이미지 2개 중 2개
      • Remove the four silver 4mm JIS #000 screws connecting the LCD screen to the back of the camera.
      • Be sure to lift the ribbon cable to remove the remaining hidden black 4mm JIS #000 screw.
      댓글 쓰기
    2. Canon EOS Rebel T5 LCD Screen Replacement: 9 단계, 이미지 1개 중 1개
      • The LCD screen can now be lifted from the right side to be replaced.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Austin Tucker
회원 가입일: 08/27/15
1,087 평판
안내서 4개를 작성함
USF Tampa, Team 16-4, Wollert Fall 2015 USF Tampa, Team 16-4, Wollert Fall 2015 회원
USFT-WOLLERT-F15S16G4
4 회원들
안내서 18개를 작성함
8가이드 댓글
This guide is NOT COMPLETE. THere are several missing screws that need to be removed.
2 from the viewfinder,
and 2 from the IO ports....
Do not follow this and force the back open or you will need more repair!
11romej - 답글 공유
Hi, I followed every step and replaced the LCD screen but when turned on the camera, I only got a yellow horizontal line. Do you know what could have gone wrong? Thank you.
Griselda Garcia - 답글 공유
Hi, excellent guide but I’ve a problem.
I’m need to buy a lcd display. Do you know where can I buy ? Can you recommend me one store to buy it?
Nicolás Morales - 답글 공유
@nickmorales I found the lcd display as well as the connected controller card ar eBay.
Tom Kane
Tom Kane - 답글 공유
I had problems connected the actual LCD component to the controller card, as seen in step 9. We need more illustrations for actually connecting the ribbon cables (plural!) and for actually mounting the LCD and the controller card.
Tom Kane
Tom Kane - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 87
전체 시간: 9,979
