주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon EOS Rebel XTi Shutter Button Replacement
필요한 것
    1. Canon EOS Rebel XTi Shutter Button Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Place the camera upside down, and position it to where the back of the camera is visible.
      댓글 쓰기
    2. Canon EOS Rebel XTi Shutter Button Replacement: 2 단계, 이미지 1개 중 1개
      • Pull the orange tab to the right to release the primary battery.
      댓글 쓰기
    3. Canon EOS Rebel XTi Shutter Button Replacement: 3 단계, 이미지 1개 중 1개
      • To remove the secondary battery, reposition the camera to where the display screen is facing upwards.
      • Place your finger inside the empty battery compartment and pull away from the camera on the ridged battery tab.
      댓글 쓰기
    1. Canon EOS Rebel XTi Shutter Button Replacement, Memory Card: 4 단계, 이미지 1개 중 1개
      • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
      댓글 쓰기
    2. Canon EOS Rebel XTi Shutter Button Replacement: 5 단계, 이미지 1개 중 1개
      • Slide the memory card door in the direction of the arrow engraved on the camera.
      • Once the door has slid open to its full position, lift up on the door.
      댓글 쓰기
    3. Canon EOS Rebel XTi Shutter Button Replacement: 6 단계, 이미지 1개 중 1개
      • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
      • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
      댓글 쓰기
    1. Canon EOS Rebel XTi Shutter Button Replacement, Back Cover: 7 단계, 이미지 1개 중 1개
      • Remove the three black M3x4mm JIS #000 screws on the bottom of the camera.
      댓글 쓰기
    2. Canon EOS Rebel XTi Shutter Button Replacement: 8 단계, 이미지 2개 중 1개 Canon EOS Rebel XTi Shutter Button Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the two black M3x6mm JIS #000 screws from the right side of the camera.
      댓글 쓰기
    3. Canon EOS Rebel XTi Shutter Button Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the two M3x5mm JIS #000 screws on the side of the camera opposite to the hand grip.
      댓글 쓰기
    4. Canon EOS Rebel XTi Shutter Button Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the following screws located in the memory card slot:
      • Two M3x2mm JIS #000 screws
      댓글 쓰기
    5. Canon EOS Rebel XTi Shutter Button Replacement: 11 단계, 이미지 1개 중 1개
      • Gently pry off the back casing.
      • Before completely removing the back casing, be sure to disconnect the single ribbon cable running from the motherboard to the LCD display.
      • Use a spudger to lift the tab on the ribbon cable's ZIF connector.
      • Gently pull the ribbon cable out of the connector.
      댓글 쓰기
    1. Canon EOS Rebel XTi Shutter Button Replacement, Front Cover: 12 단계, 이미지 1개 중 1개
      • Remove the following screws from the bottom of the camera:
      • Two M3x4.5mm JIS #000 screws
      • One M3x3mm JIS #000 screw
      댓글 쓰기
    2. Canon EOS Rebel XTi Shutter Button Replacement: 13 단계, 이미지 1개 중 1개
      • Remove the following screws from the front of the camera:
      • Two M3x6mm JIS #000 screws
      댓글 쓰기
    3. Canon EOS Rebel XTi Shutter Button Replacement: 14 단계, 이미지 1개 중 1개
      • Gently pry off the front casing.
      • There are no ribbon cables to remove for this portion of the disassembly.
      댓글 쓰기
    1. Canon EOS Rebel XTi Shutter Button Replacement, Top Cover: 15 단계, 이미지 3개 중 1개 Canon EOS Rebel XTi Shutter Button Replacement, Top Cover: 15 단계, 이미지 3개 중 2개 Canon EOS Rebel XTi Shutter Button Replacement, Top Cover: 15 단계, 이미지 3개 중 3개
      • Remove the following screws from around the viewfinder:
      • One 10mm JIS #00 diopter screw
      • Two M3x6mm JIS #00 screws
      댓글 쓰기
    2. Canon EOS Rebel XTi Shutter Button Replacement: 16 단계, 이미지 3개 중 1개 Canon EOS Rebel XTi Shutter Button Replacement: 16 단계, 이미지 3개 중 2개 Canon EOS Rebel XTi Shutter Button Replacement: 16 단계, 이미지 3개 중 3개
      • Remove the following screws on each side of the camera under the strap hooks:
      • One M3x5mm JIS #00 screw
      • One M3x4.5mm JIS #00 screw
      댓글 쓰기
    3. Canon EOS Rebel XTi Shutter Button Replacement: 17 단계, 이미지 1개 중 1개
      • Separate the top casing from the electrical components enough to expose the wire harnesses that will need to be disconnected.
      • Ensure to remove the casing gently. There are several wire harnesses connecting the motherboard to components on the casing.
      댓글 쓰기
    4. Canon EOS Rebel XTi Shutter Button Replacement: 18 단계, 이미지 1개 중 1개
      • Unplug the yellow connector located on the top of the camera.
      댓글 쓰기
    5. Canon EOS Rebel XTi Shutter Button Replacement: 19 단계, 이미지 1개 중 1개
      • Disconnect the red connector located by the USB port.
      댓글 쓰기
    1. Canon EOS Rebel XTi Shutter Button Replacement, Shutter Button: 20 단계, 이미지 1개 중 1개
      • Use a JIS #00 screwdriver to remove the two silver 4 mm screws from underneath the shutter button.
      댓글 쓰기
    2. Canon EOS Rebel XTi Shutter Button Replacement: 21 단계, 이미지 3개 중 1개 Canon EOS Rebel XTi Shutter Button Replacement: 21 단계, 이미지 3개 중 2개 Canon EOS Rebel XTi Shutter Button Replacement: 21 단계, 이미지 3개 중 3개
      • Use a JIS #00 screwdriver to remove the 3mm screws from the plate under the shutter button.
      • Place the components off to the side without removing any ribbons.
      • Be careful as ribbon cables are fragile and may rip easily.
      댓글 쓰기
    3. Canon EOS Rebel XTi Shutter Button Replacement: 22 단계, 이미지 1개 중 1개
      • Use a 1.5mm flat head bit to remove the c-clip from underneath the snapshot button by pushing against the open side of the pin.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Luis Calle
회원 가입일: 08/30/15
431 평판
안내서 3개를 작성함
USF Tampa, Team 8-6, Eyestone Fall 2015 USF Tampa, Team 8-6, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S8G6
3 회원들
안내서 55개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 50
전체 시간: 1,675
