주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon ImageCLASS MF4350d Scanner Belt Replacement
필요한 것
    1. Canon ImageCLASS MF4350d Scanner Belt Replacement, Scanner Disassembly: 1 단계, 이미지 1개 중 1개
      • If at any point you see glass that seems cracked or broken, handle with care. Broken glass is sharp and can cause serious damage.
      • Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
      댓글 쓰기
    2. Canon ImageCLASS MF4350d Scanner Belt Replacement: 2 단계, 이미지 3개 중 1개 Canon ImageCLASS MF4350d Scanner Belt Replacement: 2 단계, 이미지 3개 중 2개 Canon ImageCLASS MF4350d Scanner Belt Replacement: 2 단계, 이미지 3개 중 3개
      • Locate the black and white hinges.
      • Gently lift out the black and white hinges.
      댓글 쓰기
    3. Canon ImageCLASS MF4350d Scanner Belt Replacement: 3 단계, 이미지 3개 중 1개 Canon ImageCLASS MF4350d Scanner Belt Replacement: 3 단계, 이미지 3개 중 2개 Canon ImageCLASS MF4350d Scanner Belt Replacement: 3 단계, 이미지 3개 중 3개
      • Next, locate and remove the four 10mm screws.
      댓글 쓰기
    4. Canon ImageCLASS MF4350d Scanner Belt Replacement: 4 단계, 이미지 1개 중 1개
      • Gently, pry off the top plate, starting from the back of the printer.
      댓글 쓰기
    5. Canon ImageCLASS MF4350d Scanner Belt Replacement: 5 단계, 이미지 2개 중 1개 Canon ImageCLASS MF4350d Scanner Belt Replacement: 5 단계, 이미지 2개 중 2개
      • After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
      댓글 쓰기
    1. Canon ImageCLASS MF4350d Scanner Belt Replacement, Scanner Belt: 6 단계, 이미지 2개 중 1개 Canon ImageCLASS MF4350d Scanner Belt Replacement, Scanner Belt: 6 단계, 이미지 2개 중 2개
      • Remove the black component by gently pulling it up from the black scanner belt
      댓글 쓰기
    2. Canon ImageCLASS MF4350d Scanner Belt Replacement: 7 단계, 이미지 2개 중 1개 Canon ImageCLASS MF4350d Scanner Belt Replacement: 7 단계, 이미지 2개 중 2개
      • Press down on the white release and force it in toward the spring as shown. While you do this, pull the scanner belt out of the track.
      • Take a new belt and put it in the same way that you took it out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Tanner Papenfuss
회원 가입일: 09/30/13
584 평판
안내서 4개를 작성함
Cal Poly, Team 13-1, Forte Fall 2013 Cal Poly, Team 13-1, Forte Fall 2013 회원
CPSU-FORTE-F13S13G1
5 회원들
안내서 17개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 75
전체 시간: 3,702
