주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon ImageCLASS MF4350d Speaker Replacement
필요한 것
    1. Canon ImageCLASS MF4350d Speaker Replacement, Front Paneling: 1 단계, 이미지 1개 중 1개
      • Lift the printer lid up as shown in the photo.
      댓글 쓰기
    2. Canon ImageCLASS MF4350d Speaker Replacement: 2 단계, 이미지 2개 중 1개 Canon ImageCLASS MF4350d Speaker Replacement: 2 단계, 이미지 2개 중 2개
      • Locate and remove the two 10mm side screws. There is one on each side.
      댓글 쓰기
    3. Canon ImageCLASS MF4350d Speaker Replacement: 3 단계, 이미지 2개 중 1개 Canon ImageCLASS MF4350d Speaker Replacement: 3 단계, 이미지 2개 중 2개
      • Unhook the plastic panel from the printer starting from the top.
      • You may need to wiggle the panel a bit to loosen it.
      • To remove the bottom part of the paneling gently lay the printer on its back.
      • The scanner lid needs to be supported when moving the printer
      댓글 쓰기
    1. Canon ImageCLASS MF4350d Speaker Replacement, Right Side Paneling: 4 단계, 이미지 3개 중 1개 Canon ImageCLASS MF4350d Speaker Replacement, Right Side Paneling: 4 단계, 이미지 3개 중 2개 Canon ImageCLASS MF4350d Speaker Replacement, Right Side Paneling: 4 단계, 이미지 3개 중 3개
      • Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
      • Use a gentle back and forth motion to wiggle the hooks out.
      댓글 쓰기
    1. Canon ImageCLASS MF4350d Speaker Replacement, Speaker: 5 단계, 이미지 1개 중 1개
      • Lay printer on its left side for better access to the speaker.
      댓글 쓰기
    2. Canon ImageCLASS MF4350d Speaker Replacement: 6 단계, 이미지 2개 중 1개 Canon ImageCLASS MF4350d Speaker Replacement: 6 단계, 이미지 2개 중 2개
      • Using a Phillips head screw driver, unscrew the 7mm screw.
      댓글 쓰기
    3. Canon ImageCLASS MF4350d Speaker Replacement: 7 단계, 이미지 3개 중 1개 Canon ImageCLASS MF4350d Speaker Replacement: 7 단계, 이미지 3개 중 2개 Canon ImageCLASS MF4350d Speaker Replacement: 7 단계, 이미지 3개 중 3개
      • Locate the red and black wires connected to the speaker.
      • Undo the white clip holding the wires in place by pinching the tab on the top.
      • Remove the red and black wires from the wire bundle.
      • When replacing the old speaker, do not touch any part of the new speaker that is not metal other than the wires. Doing so could damage the speaker.
      • Lift out the speaker
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Helena Yanez
회원 가입일: 09/29/13
470 평판
안내서 4개를 작성함
Cal Poly, Team 13-1, Forte Fall 2013 Cal Poly, Team 13-1, Forte Fall 2013 회원
CPSU-FORTE-F13S13G1
5 회원들
안내서 17개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 29
전체 시간: 1,823
