주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PIXMA MP620B Ink Head Replacement
필요한 것
    1. Canon PIXMA MP620B Ink Head Replacement, Ink Head: 1 단계, 이미지 2개 중 1개 Canon PIXMA MP620B Ink Head Replacement, Ink Head: 1 단계, 이미지 2개 중 2개
      • There are a few tabs on the top of the panel that hook down and into the black side panel. Insert the tool in-between the black panel and the blue panel as shown and pull the two pieces apart.
      • You will hear some snapping. Don't panic: this is just the hooks un-clipping.
      댓글 쓰기
    2. Canon PIXMA MP620B Ink Head Replacement: 2 단계, 이미지 2개 중 1개 Canon PIXMA MP620B Ink Head Replacement: 2 단계, 이미지 2개 중 2개
      • Repeat the same process on the left side panel.
      댓글 쓰기
    3. Canon PIXMA MP620B Ink Head Replacement: 3 단계, 이미지 1개 중 1개
      • Unhook the lid support by sliding the hook down and to the left. Make sure the support is fully disconnected before proceeding.
      댓글 쓰기
    4. Canon PIXMA MP620B Ink Head Replacement: 4 단계, 이미지 2개 중 1개 Canon PIXMA MP620B Ink Head Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the four black screws on the back panels from both the left and right side.
      댓글 쓰기
    5. Canon PIXMA MP620B Ink Head Replacement: 5 단계, 이미지 3개 중 1개 Canon PIXMA MP620B Ink Head Replacement: 5 단계, 이미지 3개 중 2개 Canon PIXMA MP620B Ink Head Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the scanner by pulling the side panels out until the scanner pin is free. Set the scanner aside.
      • The scanner will still be attached with wires on the right side. Be careful not to yank the part away from the main body of the printer.
      댓글 쓰기
    6. Canon PIXMA MP620B Ink Head Replacement: 6 단계, 이미지 2개 중 1개 Canon PIXMA MP620B Ink Head Replacement: 6 단계, 이미지 2개 중 2개
      • Press down on the clip on the left side of the printer until it clicks, and pull the panel free.
      댓글 쓰기
    7. Canon PIXMA MP620B Ink Head Replacement: 7 단계, 이미지 2개 중 1개 Canon PIXMA MP620B Ink Head Replacement: 7 단계, 이미지 2개 중 2개
      • Press down on the clip on the right side panel until it clicks and then pull the panel free.
      댓글 쓰기
    8. Canon PIXMA MP620B Ink Head Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the plastic cover by depressing the clip located on the right side of the printer. Press the clip inwards until it clicks, and then lift the cover upwards and off the printer.
      댓글 쓰기
    9. Canon PIXMA MP620B Ink Head Replacement, Remove the three screws holding the top rear slider rail: 9 단계, 이미지 2개 중 1개 Canon PIXMA MP620B Ink Head Replacement, Remove the three screws holding the top rear slider rail: 9 단계, 이미지 2개 중 2개
      • Unscrew the three screws holding the rail.
      댓글 쓰기
    10. Canon PIXMA MP620B Ink Head Replacement, Remove the guiding cord: 10 단계, 이미지 1개 중 1개
      • Remove the cord by pulling upwards on it and unhooking it from the pulleys on either end.
      댓글 쓰기
    11. Canon PIXMA MP620B Ink Head Replacement, Remove the ink head: 11 단계, 이미지 1개 중 1개
      • Remove the ink head by pulling it away from the rail.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Val Fedorikhin
회원 가입일: 10/12/14
860 평판
안내서 5개를 작성함
Cal Poly, Team 6-21, Maness Fall 2014 Cal Poly, Team 6-21, Maness Fall 2014 회원
CPSU-MANESS-F14S6G21
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 51
전체 시간: 3,705
