주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot A200 LCD Display Replacement
필요한 것
    1. Canon PowerShot A200 LCD Display Replacement, Canon PowerShot A200: 1 단계, 이미지 1개 중 1개
      • Use a Phillips #00 screwdriver to remove the two screws located at the bottom of the camera.
      댓글 쓰기
    2. Canon PowerShot A200 LCD Display Replacement: 2 단계, 이미지 2개 중 1개 Canon PowerShot A200 LCD Display Replacement: 2 단계, 이미지 2개 중 2개
      • Locate the screw and the rubber covering on the left side of the camera. Slide the rubber covering to expose a second screw.
      • Remove the two screws with the Phillips #00 screwdriver.
      댓글 쓰기
    3. Canon PowerShot A200 LCD Display Replacement: 3 단계, 이미지 2개 중 1개 Canon PowerShot A200 LCD Display Replacement: 3 단계, 이미지 2개 중 2개
      • Open the battery compartment on the right side of the camera by pushing slightly in the direction of the arrow.
      • Be sure to remove the memory card.
      • Remove the two screws by the memory card slot using the Phillips #00 screwdriver.
      댓글 쓰기
    4. Canon PowerShot A200 LCD Display Replacement: 4 단계, 이미지 2개 중 1개 Canon PowerShot A200 LCD Display Replacement: 4 단계, 이미지 2개 중 2개
      • Pull the grey tab towards the back of the camera. Lift the black cover to expose the battery slots.
      • Remove the two visible screws with the Phillips #00 screwdriver.
      • During reassembly, the holes for these screws must align properly with the interior of the camera body. Then the black battery cover must lie flat and be held in place by the grey tab.
      댓글 쓰기
    5. Canon PowerShot A200 LCD Display Replacement: 5 단계, 이미지 2개 중 1개 Canon PowerShot A200 LCD Display Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the screen battery located to the left of the screen.
      • Set the screen battery aside for reassembly
      댓글 쓰기
    6. Canon PowerShot A200 LCD Display Replacement: 6 단계, 이미지 2개 중 1개 Canon PowerShot A200 LCD Display Replacement: 6 단계, 이미지 2개 중 2개
      • Gently pull the camera apart from the top.
      • Be careful. The two halves are still attached by two short ribbons at the bottom of the camera.
      댓글 쓰기
    7. Canon PowerShot A200 LCD Display Replacement: 7 단계, 이미지 2개 중 1개 Canon PowerShot A200 LCD Display Replacement: 7 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Locate the black tabs on either side of the white ribbon.
      • Use the metal tweezers to gently move these tabs to the outside edges of the ribbon.
      • Gently pull the white ribbon out from its connection.
      댓글 쓰기
    8. Canon PowerShot A200 LCD Display Replacement: 8 단계, 이미지 3개 중 1개 Canon PowerShot A200 LCD Display Replacement: 8 단계, 이미지 3개 중 2개 Canon PowerShot A200 LCD Display Replacement: 8 단계, 이미지 3개 중 3개
      • Locate the black tabs on either side of the orange ribbon.
      • Gently pull the orange ribbon out of its connection.
      • Your camera will now be in two separate pieces.
      댓글 쓰기
    1. Canon PowerShot A200 LCD Display Replacement, LCD Display: 9 단계, 이미지 1개 중 1개
      • Use a Phillips head screwdriver to remove the four screws from the corners of the LCD.
      댓글 쓰기
    2. Canon PowerShot A200 LCD Display Replacement: 10 단계, 이미지 1개 중 1개
      • Use the iFixit plastic opening tool to lift the LCD away from the back case.
      • The LCD will still be attached to the back of the camera case by an orange strip.
      댓글 쓰기
    3. Canon PowerShot A200 LCD Display Replacement: 11 단계, 이미지 1개 중 1개
      • Use a soldering iron to remove the LCD from the orange cable connected to the back of the camera.
      • Use the soldering iron to attach your new LCD in place.
      • Caution: When soldering, allow enough slack in the orange cable, so the LCD will lie flat. The white bar will lie parallel with the electronic components embedded in the motherboard.
      댓글 쓰기
결론
Follow the instructions in the prerequisite guide Disassembling the Canon PowerShot A200 Case.
Once completed, proceed with installing a new LCD Display.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
12다른 기여자 명과 함께
Jeff Barich
회원 가입일: 01/28/11
101 평판
안내서 1개를 작성함
Cal Poly, Team 7-37, Regan Winter 2011 Cal Poly, Team 7-37, Regan Winter 2011 회원
CPSU-REGAN-W11S7G37
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 34
전체 시간: 1,421
