주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot A2200 Button Assembly Replacement
필요한 것
    1. Canon PowerShot A2200 Button Assembly Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • First, remove the batteries and memory card.
      • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
      • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
      댓글 쓰기
    2. Canon PowerShot A2200 Button Assembly Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
      댓글 쓰기
    3. Canon PowerShot A2200 Button Assembly Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
      댓글 쓰기
    4. Canon PowerShot A2200 Button Assembly Replacement: 4 단계, 이미지 3개 중 1개 Canon PowerShot A2200 Button Assembly Replacement: 4 단계, 이미지 3개 중 2개 Canon PowerShot A2200 Button Assembly Replacement: 4 단계, 이미지 3개 중 3개
      • Begin taking off the back cover with a plastic opening tool.
      • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
      • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
      • Continue taking off the back cover along the left side of the camera as seen in the third picture.
      댓글 쓰기
    5. Canon PowerShot A2200 Button Assembly Replacement: 5 단계, 이미지 3개 중 1개 Canon PowerShot A2200 Button Assembly Replacement: 5 단계, 이미지 3개 중 2개 Canon PowerShot A2200 Button Assembly Replacement: 5 단계, 이미지 3개 중 3개
      • Use the plastic opening tool to separate the top section of the back cover from the frame.
      • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
      댓글 쓰기
    1. Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: 6 단계, 이미지 2개 중 1개 Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: 6 단계, 이미지 2개 중 2개
      • Remove the internal 4.4mm screw with a Phillips 00 screwdriver.
      • Make sure you're removing the screw circled in red, not the screw crossed out in orange.
      댓글 쓰기
    2. Canon PowerShot A2200 Button Assembly Replacement: 7 단계, 이미지 1개 중 1개
      • Gently lift of the buttons for replacement. They should come off without excessive force.
      • If the buttons do not lift off easily, you may have unscrewed the wrong screw. Revert to previous step.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Benjamin Gee
회원 가입일: 03/31/15
983 평판
안내서 5개를 작성함
Baylor, Team 4-5, Williams Spring 2015 Baylor, Team 4-5, Williams Spring 2015 회원
BU-WILLIAMS-S15S4G5
4 회원들
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 29
전체 시간: 1,100
