주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot A2300 Flash Assembly Replacement
필요한 것
    1. Canon PowerShot A2300 Flash Assembly Replacement, Front Cover: 1 단계, 이미지 1개 중 1개
      • Open the A/V Out Digital port cover on the function button side to reveal a screw.
      댓글 쓰기
    2. Canon PowerShot A2300 Flash Assembly Replacement: 2 단계, 이미지 3개 중 1개 Canon PowerShot A2300 Flash Assembly Replacement: 2 단계, 이미지 3개 중 2개 Canon PowerShot A2300 Flash Assembly Replacement: 2 단계, 이미지 3개 중 3개
      • Remove all 6 screws(2.70 mm), 2 on each side and 2 on the bottom.
      • Screws are small and very easily lost.
      댓글 쓰기
    3. Canon PowerShot A2300 Flash Assembly Replacement: 3 단계, 이미지 2개 중 1개 Canon PowerShot A2300 Flash Assembly Replacement: 3 단계, 이미지 2개 중 2개
      • Open the card/battery latch by sliding the cover away from the camera in the direction indicated by the arrow.
      • Doing this gives a spot to grip on the bottom of the front cover. This will make it easier to handle when removing.
      댓글 쓰기
    4. Canon PowerShot A2300 Flash Assembly Replacement: 4 단계, 이미지 1개 중 1개
      • Gently lift the bottom of the front cover to roughly a 30 degree angle.
      댓글 쓰기
    5. Canon PowerShot A2300 Flash Assembly Replacement: 5 단계, 이미지 1개 중 1개
      • Pull the top of the front cover away from the camera by gripping the top of the front cover by the corners where the cover is still attached to the body.
      댓글 쓰기
    1. Canon PowerShot A2300 Flash Assembly Replacement, Back Cover: 6 단계, 이미지 1개 중 1개
      • Hold the camera in your hands with both thumbs on the screen with the screen faced up.
      • Keep close to the table top in case the camera falls out of your hands.
      댓글 쓰기
    2. Canon PowerShot A2300 Flash Assembly Replacement: 7 단계, 이미지 1개 중 1개
      • Pull the the bottom left corner of the cover up about an inch to the point shown in the picture.
      • Do not completely remove the back cover by pulling on the side as shown. The cover is still attached on the top of the camera.
      댓글 쓰기
    3. Canon PowerShot A2300 Flash Assembly Replacement: 8 단계, 이미지 1개 중 1개
      • Pry the top off by sliding the spudger under the On/Off button.
      댓글 쓰기
    4. Canon PowerShot A2300 Flash Assembly Replacement: 9 단계, 이미지 1개 중 1개
      • Slide the cover to the right and off the camera.
      • Gently pry using the spudger on the right side if necessary.
      • The A/V OUT DIGITAL cover will sometimes become loose and disconnect from the cover
      댓글 쓰기
    1. Canon PowerShot A2300 Flash Assembly Replacement, Flash Assembly: 10 단계, 이미지 1개 중 1개
      • Raise the screen by wedging the spudger between the bottom of the screen and the mount hole.
      댓글 쓰기
    2. Canon PowerShot A2300 Flash Assembly Replacement: 11 단계, 이미지 1개 중 1개
      • Remove the metal sheet that is under the screen.
      댓글 쓰기
    3. Canon PowerShot A2300 Flash Assembly Replacement: 12 단계, 이미지 1개 중 1개
      • Remove the top left screw on the metal sheet that is behind the screen.
      • This screw connects the flash to the metal sheet.
      댓글 쓰기
    4. Canon PowerShot A2300 Flash Assembly Replacement: 13 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use one side of the tweezers to raise the orange retaining flap on the zero insertion force (ZIF) connector to a vertical position.
      댓글 쓰기
    5. Canon PowerShot A2300 Flash Assembly Replacement: 14 단계, 이미지 1개 중 1개
      • Gently pull the orange ribbon cable out of the ZIF connector using the tweezers.
      댓글 쓰기
    6. Canon PowerShot A2300 Flash Assembly Replacement: 15 단계, 이미지 2개 중 1개 Canon PowerShot A2300 Flash Assembly Replacement: 15 단계, 이미지 2개 중 2개
      • Remove the flash by gently rotating slightly back and forth and pulling up.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nathan McMillan
회원 가입일: 03/23/15
405 평판
안내서 2개를 작성함
Baylor, Team 7-14, Williams Spring 2015 Baylor, Team 7-14, Williams Spring 2015 회원
BU-WILLIAMS-S15S7G14
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 66
전체 시간: 2,581
