주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot A2500 Buttons Replacement
필요한 것
    1. Canon PowerShot A2500 Buttons Replacement, Body Casing and Faceplate: 1 단계, 이미지 2개 중 1개 Canon PowerShot A2500 Buttons Replacement, Body Casing and Faceplate: 1 단계, 이미지 2개 중 2개
      • Remove the knot holding the wrist lanyard onto the camera
      댓글 쓰기
    2. Canon PowerShot A2500 Buttons Replacement: 2 단계, 이미지 1개 중 1개
      • Open the latch at the bottom corner of the device to reveal the battery and SD card housing.
      • There is an orange latch holding the battery in place which must be pushed back in order to free the battery.
      • Once the battery is removed push the SD card and this will activate a spring ejecting the card from the camera.
      댓글 쓰기
    3. Canon PowerShot A2500 Buttons Replacement: 3 단계, 이미지 3개 중 1개 Canon PowerShot A2500 Buttons Replacement: 3 단계, 이미지 3개 중 2개 Canon PowerShot A2500 Buttons Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the 6 Phillips #00 exterior screws from the camera. Two are located on the bottom and two are located on either side as shown. Notice that one of the screws is under the AV Out Digital flap on the side. All exterior screws should be 2.4mm in length
      댓글 쓰기
    4. Canon PowerShot A2500 Buttons Replacement: 4 단계, 이미지 3개 중 1개 Canon PowerShot A2500 Buttons Replacement: 4 단계, 이미지 3개 중 2개 Canon PowerShot A2500 Buttons Replacement: 4 단계, 이미지 3개 중 3개
      • Pry apart the camera casing using the plastic opening tool tool provided. Once the casing has begun to separate pull the two sides apart with your hands.
      • Be careful not to bend the plastic casing to much, as it will crack.
      댓글 쓰기
    1. Canon PowerShot A2500 Buttons Replacement, Buttons: 5 단계, 이미지 1개 중 1개
      • Remove the single philips #00 screw on the button pad which are 2.2mm long. This screw is circled in red in the guide image.
      • Next, remove the two 2.4mm long screws located in between the LCD screen and the touch pad. These screws will require a Phillips #00 screwdriver.
      댓글 쓰기
    2. Canon PowerShot A2500 Buttons Replacement: 6 단계, 이미지 2개 중 1개 Canon PowerShot A2500 Buttons Replacement: 6 단계, 이미지 2개 중 2개
      • Pull the two clips off located near the power button
      • The clips are easily broken, use care while disconnecting these clips.
      댓글 쓰기
    3. Canon PowerShot A2500 Buttons Replacement: 7 단계, 이미지 3개 중 1개 Canon PowerShot A2500 Buttons Replacement: 7 단계, 이미지 3개 중 2개 Canon PowerShot A2500 Buttons Replacement: 7 단계, 이미지 3개 중 3개
      • Remove the circuit ribbon connecting the flash to the camera in order to proceed to the next instruction.
      • Carefully pull out the circuit ribbon from the camera which should be the last piece holding the button pad onto the camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jeff
회원 가입일: 03/12/15
245 평판
안내서 1개를 작성함
UMass Dartmouth, Team 3-4, Duarte Spring 2015 UMass Dartmouth, Team 3-4, Duarte Spring 2015 회원
UMASSD-DUARTE-S15S3G4
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 30
전체 시간: 1,540
