주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot A2500 Flash Component Replacement
필요한 것
    1. Canon PowerShot A2500 Flash Component Replacement, Body Casing and Faceplate: 1 단계, 이미지 2개 중 1개 Canon PowerShot A2500 Flash Component Replacement, Body Casing and Faceplate: 1 단계, 이미지 2개 중 2개
      • Remove the knot holding the wrist lanyard onto the camera
      댓글 쓰기
    2. Canon PowerShot A2500 Flash Component Replacement: 2 단계, 이미지 1개 중 1개
      • Open the latch at the bottom corner of the device to reveal the battery and SD card housing.
      • There is an orange latch holding the battery in place which must be pushed back in order to free the battery.
      • Once the battery is removed push the SD card and this will activate a spring ejecting the card from the camera.
      댓글 쓰기
    3. Canon PowerShot A2500 Flash Component Replacement: 3 단계, 이미지 3개 중 1개 Canon PowerShot A2500 Flash Component Replacement: 3 단계, 이미지 3개 중 2개 Canon PowerShot A2500 Flash Component Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the 6 Phillips #00 exterior screws from the camera. Two are located on the bottom and two are located on either side as shown. Notice that one of the screws is under the AV Out Digital flap on the side. All exterior screws should be 2.4mm in length
      댓글 쓰기
    4. Canon PowerShot A2500 Flash Component Replacement: 4 단계, 이미지 3개 중 1개 Canon PowerShot A2500 Flash Component Replacement: 4 단계, 이미지 3개 중 2개 Canon PowerShot A2500 Flash Component Replacement: 4 단계, 이미지 3개 중 3개
      • Pry apart the camera casing using the plastic opening tool tool provided. Once the casing has begun to separate pull the two sides apart with your hands.
      • Be careful not to bend the plastic casing to much, as it will crack.
      댓글 쓰기
    1. Canon PowerShot A2500 Flash Component Replacement, Flash Component: 5 단계, 이미지 1개 중 1개
      • Lift LCD Display using the plastic opening tool to access the screws.
      댓글 쓰기
    2. Canon PowerShot A2500 Flash Component Replacement: 6 단계, 이미지 1개 중 1개
      • Remove top left phillips #00 screw under LCD display
      • The screw should be 3.6mm long and the face of the screw should have a 2.4mm diameter
      댓글 쓰기
    3. Canon PowerShot A2500 Flash Component Replacement: 7 단계, 이미지 2개 중 1개 Canon PowerShot A2500 Flash Component Replacement: 7 단계, 이미지 2개 중 2개
      • Once the screw is removed lift small brown tab and carefully remove the ribbon tape connecting the flash component to the camera
      • Now the flash component is completely separated from the computer and ready to be replaced or repaired
      • Be sure to have the battery removed before disconnecting this tab. This will ensure that there is no possible charge remaining in the capacitor.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
James Hickey
회원 가입일: 03/24/15
393 평판
안내서 2개를 작성함
UMass Dartmouth, Team 3-4, Duarte Spring 2015 UMass Dartmouth, Team 3-4, Duarte Spring 2015 회원
UMASSD-DUARTE-S15S3G4
4 회원들
안내서 12개를 작성함
1가이드 댓글
Great tutorial, but I am left with one problem - where can I buy a flash component? Just can’t seem to find any on the internet.
Jonathan, UK
Jonathan Mitchell - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 24
전체 시간: 1,062
