주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot A460 Back Casing Replacement
필요한 것
    1. Canon PowerShot A460 Back Casing Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
      • While still holding the switch, pull the cover down, allowing it to release and open.
      댓글 쓰기
    2. Canon PowerShot A460 Back Casing Replacement: 2 단계, 이미지 1개 중 1개
      • Tilt the camera slightly to allow the batteries to fall out.
      댓글 쓰기
    3. Canon PowerShot A460 Back Casing Replacement: 3 단계, 이미지 1개 중 1개
      • Press on and release the memory card to eject it.
      댓글 쓰기
    1. Canon PowerShot A460 Back Casing Replacement, Front Casing: 4 단계, 이미지 1개 중 1개
      • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
      • Make sure to keep the different size screws organized to make reassembling the camera simpler.
      댓글 쓰기
    2. Canon PowerShot A460 Back Casing Replacement: 5 단계, 이미지 1개 중 1개
      • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
      댓글 쓰기
    3. Canon PowerShot A460 Back Casing Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
      댓글 쓰기
    4. Canon PowerShot A460 Back Casing Replacement: 7 단계, 이미지 1개 중 1개
      • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
      댓글 쓰기
    5. Canon PowerShot A460 Back Casing Replacement: 8 단계, 이미지 2개 중 1개 Canon PowerShot A460 Back Casing Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the second battery cover on the bottom of camera.
      • Take the silver battery out of the camera.
      댓글 쓰기
    6. Canon PowerShot A460 Back Casing Replacement: 9 단계, 이미지 3개 중 1개 Canon PowerShot A460 Back Casing Replacement: 9 단계, 이미지 3개 중 2개 Canon PowerShot A460 Back Casing Replacement: 9 단계, 이미지 3개 중 3개
      • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
      • Remove the light grey, plastic piece.
      • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
      댓글 쓰기
    7. Canon PowerShot A460 Back Casing Replacement: 10 단계, 이미지 3개 중 1개 Canon PowerShot A460 Back Casing Replacement: 10 단계, 이미지 3개 중 2개 Canon PowerShot A460 Back Casing Replacement: 10 단계, 이미지 3개 중 3개
      • Slightly pull on each side of the camera. It should loosen up and come apart.
      • If it does not pull apart right away, use a little more force.
      • Do not give up!
      댓글 쓰기
    1. Canon PowerShot A460 Back Casing Replacement, Back Casing: 11 단계, 이미지 1개 중 1개
      • Remove the back case of the camera by pulling from the top.
      • Be careful when pulling off the case. There is a delicate gold ribbon connecting the bottom of the camera to the back case.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Stephanie Friend
회원 가입일: 01/18/13
132 평판
안내서 2개를 작성함
Cal Poly, Team 19-42, Regan Winter 2013 Cal Poly, Team 19-42, Regan Winter 2013 회원
CPSU-REGAN-W13S19G42
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 60
전체 시간: 4,122
